Reboot a CAS array member causes Outlook 2010 clients to prompt for credentials.
C
Corbett Enders
Setup has a 2 member front-end CAS Array running Exchange 2010 with NLB for load balancing.
2 member DAG group hosting the mailboxes.
If I reboot a CAS array member, many (but not all) of our Outlook clients are prompted to enter their credentials. I don't believe this should happen, can someone point me in the right direction to resolve this?
C
Chris Morgan - Presidio
is it the same clients each time that get prompted? is it the same server that gets rebooted or this happens no matter which one you reboot? Are all clients a part of the domain and are they logged into the domain when using outlook?
AndyD_ [MVP]
NLB is not application aware.
I recommend doing a drainstop on the node you wish to reboot prior to the scheduled outage and give it enough time to minimize the number of affected users. Use perfmon to see view the amount of connected users and monitor. Once it reaches an acceptable level, stop the node and reboot.
User in cache mode should be the least affected.
C
Corbett Enders
Andy I suspect you are right... we'll try that the next time I feel the need to reboot a CAS server.
Chris, it happens to random users. All clients are on logged into workstations that are part of the domain using domain credentials.
I likely won't get to test this for some time... we rarely reboot our servers mid-day.
bodybybody
This is a work around, is there a solution? Windows updates, emergency reboots, monthly reboots etc. all the time at 3, 4 am in the morning.
2 CAS array
F5 LTM load balancer
2500 mailboxes
Scott
SR_
Are these NLB running in Multicast or Unicast mode?
Multicast the recommended meathod of NLB
-- Saakar "Please remember to click "Mark as Answer" on the post that helps you, and to click "Unmark as Answer" if a marked post does not actually answer your question. This can be beneficial to other community members reading the thread"
S CAS/MBX reboot best practices. Exchange Server Administration 7
I Outlook 2010 Preface comments disappear after reboot Using Outlook 4
P Stationary and view layout keep changing after reboot? Using Outlook 1
A Outlook.exe 32 process hangs, can't be ended without reboot Using Outlook 1
P Two Member DAG - Reboot Witness Server - Effects? Exchange Server Administration 7
S After reboot pst file is reindexed Using Outlook 8
S Exchange 2010 to SP1 Upgrade: Reboot error Exchange Server Administration 1
T Unable to open outlook a second time unless I reboot computer. Running XP and microsoft 2007 Using Outlook 6
A When I log out of Outlook. The icon on the taskbar is greyed out and I am not able to activate/launch Outlook unless I reboot my PC. I have XP and am Using Outlook 2
J VBA code (rules) won't work after reboot Outlook VBA and Custom Forms 2
D Why does my Outlook 2003 .Com Add-In disappears after reboot! Outlook VBA and Custom Forms 4
C Watson Error on CAS Exchange Server Administration 1
S Exchange CAS server OAB directory not showing web.config file Exchange Server Administration 3
T RBAC Error on UM/CAS Servers Exchange Server Administration 2
R FQDN of Exchange CAS servers not in SSL cert Exchange Server Administration 2
D CAS Design Question Exchange Server Administration 4
D Exchange 2010 CAS at 2 different Sites Exchange Server Administration 2
T Cas server uninstall failed... Now how to reinstall? Exchange Server Administration 4
S Any system impact if change exchange 2010 CAS/HUB and Mailbox server IP address Exchange Server Administration 1
B Re: Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 15
M Re: Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 2
I Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 4
M CAS Issue: OWA/Outlook remote users cannot login Exchange Server Administration 1
C CAS Proxy problem Exchange Server Administration 5
K Exchange 2010 OWA redirection between 2 CAS Servers Exchange Server Administration 5
S exchange 2010 cas memory usage Exchange Server Administration 2
P Exchange 2010 SP1 Cross Site CAS connection disable Exchange Server Administration 2
H Outlook 2007 periodically disconnects from Exchange 2010 CAS - OWA works Using Outlook 4
C CAS Connections overview Exchange Server Administration 9
