Outlook 2010 - Calendar in public folder issue
aroby
I am trying to set up a shared calendar that can be accessed within an Exchange environment and that also can be accessed externally. To do this, I have set up a calendar in a public folder - this allows me to email appointments to that folder and have them appear on the calendar. I have also published the calendar on a WebDav site. All of this works fine.
What doesn't work is viewing the calendar in the owning Exchange environment. In Outlook 2010 I can view the calendar by selecting it from the public folder. If I try to add the calendar to a calendar group, I select it from the Address Book under Public Folders and it get added. However, when it is displayed, there is a yellow diamond with an exclamation mark on the top tab saying "could not be updated". Selecting the Properties shows the error: "Cannot display folder properties. The folder may have been deleted ... You don't have appropriate permission ...". Yet I can view the properties on the calendar when it is displayed in the public folder.
Any ideas as to what is going on ?
Anthony
Forum Admin
I know you can have public folder calendars in groups, because i have some in groups.
I don't think it matters, but are you caching public folders?
myorns
Anthony, did you ever resolve this issue? I want to implement a public calendar for a conference room in our company, but this seems to be a stumbling block. Adopting new things is hard enough and the smallest hiccup will cause people to drop it before giving it a chance.
Intuitive
Anthony,
Did that fix the issue for you? (putting the Calendar in the Public Folders first)
Regards,
Jason
PDMeat
Anthony,
Regards,
Jason
Different poster here: I have this problem and adding it to Public Folder favorites was what did the trick for me. Do not add the calendar using the address book, browse PF and make it a favorite and that fixes the issue.
Thanks for the bug MS!
J Outlook 2010 and 2013 'team' calendar shows AD accounts without mailboxes Using Outlook 5
T Outlook 2010 calendar won't sync with Android phone Using Outlook 3
I Outlook 2010 calendar hangs Exchange Server Administration 2
J Importing to the correct calendar from Excel 2010 to Outlook 2010 Outlook VBA and Custom Forms 2
P Outlook 2010 MS Exchange Calendar to Android- ical or webdav? Using Outlook 1
R How to copy outlook 2010 shared calendar appointment or meeting to personal calendar by vba? Outlook VBA and Custom Forms 1
T Importing Excel 2010 data into Outlook Calendar 2010 Using Outlook 12
S Outlook 2010 trying to default Data file to outlook.com calendar Using Outlook 6
A Yearly Calendar in Outlook 2010 64 bit. Using Outlook 1
A Shared Calendar Outlook 2010 Using Outlook 4
S Outlook 2010 .pst calendar Using Outlook 1
D Outlook 2010 Calendar Alerts Using Outlook 1
S Using both My Calendar and iCloud Calendar in Outlook 2010 Using Outlook 4
M Outlook 2010 Calendar error Operation Failed Using Outlook 6
B How to have Outlook 2010 Calendar when your mail server is Imap? Using Outlook 10
D Priting only Recurring Appointments in Outlook Calendar 2010 Using Outlook 1
O Calendar list view in Outlook 2010? Using Outlook 3
J calendar print setup in outlook 2010 Calendar Printing Assistant 1
T Calendar sync off by 1 hour - outlook 2010 / icloud 2.1 / ipad Using Outlook 2
A Adding Work Calendar to my iPhone 4S from Outlook 2010 and vice a versa. Using Outlook 5
W Calendar Printing with Outlook 2010 (64 bit) Calendar Printing Assistant 1
D Calendar Permissions Outlook 2003, 2007 and 2010 Exchange Server Administration 2
D Outlook 2010 - Calendar - always show 4 weeks in month view Using Outlook 3
T Exchange / Outlook 2010 - How to cancel meetings but retain the calendar entry Using Outlook 4
P Multiple accounts and single Calendar file (Outlook 2010, using Connector) Using Outlook 1
J Outlook 2010 - missing "Updated: ... " in subject text after calendar update Using Outlook 2
K Outlook 2010 calendar issue - accepting meetings Using Outlook 3
H Conflicts with other event in calendar ( outlook 2007 & 2010) Using Outlook 0
D Outlook 2007 & 2010 calendar permissions Using Outlook 2
C Outlook 2010 search for question mark in calendar Using Outlook 7
T Outlook 2010 Calendar Using Outlook 7
L Outlook 2010 Default Calendar Using Outlook 2
K Outlook 2010 'cannot send on behalf of' when changing calendar apointment Exchange Server Administration 0
S Calendar sharing problmes between Outlook 2007 & 2010 Exchange Server Administration 0
B Linking from Excel to public outlook 2010 calendar. Using Outlook 0
J Outlook 2007 and 2010 for multiple calendar users Using Outlook 1
D searching Outlook 2010 Calendar Using Outlook 1
T Dates are not in bold from a shared calendar (Outlook 2010 ) Using Outlook 1
E Outlook 2010 calendar print - select begin-end weeks for month print but Preview and print show ful Using Outlook 2
K Outlook 2010 Calendar: could not be updated Using Outlook 3
W Unable to sync Outlook contacts and calendar since upgrading from Outlook 2007 to Outlook 2010 Using Outlook 1
J Calendar print assistant outlook 2010 Using Outlook 3
C print more than one month per page in outlook 2010 calendar Using Outlook 5
K Recurring meetings don't show on calendar Outlook 2010 Using Outlook 1
C Calendar Printing Assistant for Outlook 2010 Using Outlook 2
L Calendar rules in Outlook 2010 Using Outlook 3
B Outlook 2010 calendar month view colorisation bug Using Outlook 1
