Calendar printing and print preview differs from screen view
F
flowergal
I want to lighten or remove the lines around the dates on the monthly calendar when printing. On the screen they are a soft shaded color but when printing they are a dark thick line.
Are you using the calendar printing assistant?
AFAIK, the line darkness is controled by the printer drivers - its not customizable in Outlook. If you use the calendar printing assistant you might be able ot edit the template to remove the lines.
basic info on modifying templates is here: http://www.slipstick.com/outlook/ol2007/editcpao.asp
J Microsoft Outlook Calendar - end time of appointment has started printing but don't want it to print Using Outlook 2
H How to print multiple calendars using calendar printing assistant Using Outlook 1
P printing weekly calendar in Outlook 2013 cuts days of week off Using Outlook 1
M Calendar Printing Assistant Hangs only on specific Template Using Outlook 2
K calendar printing Using Outlook 1
S So Disappointed in Calendar Printing Assistant!! Calendar Printing Assistant 2
J Printing Calendar in Outlook 2013 Using Outlook 0
E Monthly Style Calendar Printing Using Outlook 6
P Printing calendar (work week) with numerous (i.e. >7) all day events... Calendar Printing Assistant 3
A Outlook CPAO - Printing Monthly calendar with only all day events or catergory Calendar Printing Assistant 2
E Adding Start and End Time to Daily View in Calendar Printing assistant Calendar Printing Assistant 1
S Printing Category Key on Calendar Using Outlook 1
P Printing Issue on Calendar Printing Assistant Calendar Printing Assistant 0
W Calendar Printing with Outlook 2010 (64 bit) Calendar Printing Assistant 1
R printing custom number of calendar days in weekly view format Using Outlook 1
D Printing Monthly Calendar Using Outlook 2
J Ho do I hide the week number on the Calendar Printing Assistant template Calendar Printing Assistant 4
B Can't install Calendar Printing Assistant - Windows 7 64bit&Office 2010 32bit Calendar Printing Assistant 2
J Calendar Pop-up Missing from Calendar Printing Dialogue Using Outlook 1
C Printing a monthly calendar in overlay view Calendar Printing Assistant 3
A Emailing Calendars Created in Outlook Calendar Printing Assistant Calendar Printing Assistant 3
J Printing Private Appointment Detail on Calendar Printing Assistance Calendar Printing Assistant 0
C Calendar Printing Assistant for Outlook 2010 Using Outlook 2
D Old recurring appointments showing up in Calendar Printing Assistant Using Outlook 6
A Cannot Turn off end date in Calendar Printing Assistant Using Outlook 1
D Trouble downloading Calendar Printing Assistant for Outlook 2010 Using Outlook 2
D Printing calendar - Change color of meeting time Using Outlook 1
R 2010 Calendar Printing Assistant Month View Using Outlook 1
S Labels Not Printing on Calendar Calendar Printing Assistant 3
H Is there an easy way to set the date range when printing a calendar? Using Outlook 1
B Outlook 2007 Calendar Printing with large font Using Outlook 1
G Using Outlook Calendar Printing Assistant in Outlook 2010 Using Outlook 6
J Outlook not printing October 23-31 in Calendar Using Outlook 1
B Calendar Printing only prints two lines Using Outlook 3
J Calendar appointment details will not show when printing Using Outlook 8
B printing a calendar on a single page using CPA Calendar Printing Assistant 0
N Outlook 2007 Monthly Calendar printing without meeting details. Using Outlook 5
Forum Admin Calendar Printing Assistant v2 Calendar Printing Assistant 0
T Printing problem in Calendar Printing Assistant Calendar Printing Assistant 3
M Calendar Printing Assistant that Works & is Supported Outlook Wishlist 1
U Printing calendar weeks without three lines for tasks under each d Calendar Printing Assistant 2
Y Outlook 2010 or Calendar Printing Assistant Calendar Printing Assistant 2
V Calendar Printing Assistant Crashing on Me Calendar Printing Assistant 1
T Calendar Printing Assistant Crashes - Cannot Uninstall Calendar Printing Assistant 8
Q Calendar Printing Assistant Calendar Printing Assistant 2
B Outlook Calendar not coming down from cloud Using Outlook 2
N Having Shared Calendar shift to Current day Using Outlook 0
