Outlook 2003 incoming HTML does not display correctly
Techwest
Outlook 2003 running under Windows 7 Ultimate. I have my mail options set to display HTML but it does not.
I have read another ugly thread here on the same subject, dated a few months ago, and there was no solution, and no logical reason for the error. [per the person answering the thread]. Let me give a simple example: a good sender [a subscriiption I have] sends a daily briefing in HTML format, well laid-out. Under Windows XP with Outlook Express it displayed perfectly. I now run Windows 7 Ultimate 64bit with Office Profession 2003, and use the Outlook Connector with Outlook 2003, and am updated fully [sp3, patches, etc.] I do not use windows Essentials. Scanning is via Avast Home Edition but the scanning is toggled off. The same subscription message is rendered as text, and appears to the eye to be bolded but that may be the font choice substitution. I can open the same message in IE8 web browser using hotmail.com webmail and it looks great... correct... HTML formatted.
I've crawled through lots of messages on the subject but find no cause or cure.
Any ideas?
C Outlook 2003. All incoming emails go to Junk folder. Using Outlook 2
O Duplicate folders in Outlook 2003 Using Outlook 3
O Moving OUtlook 2003 from bad XP to Win 7 Pro 64 -- URGENT! Using Outlook 8
R Menus in a new\old email not there in Outlook 2003 Using Outlook 2
R OUTLOOK 2003 on WinXP, Prob: CONTACTS or ADDRESS BOOK not connected or missing Using Outlook 6
R Outlook 2003 not working Using Outlook 13
C Outlook 2003 displays wrong account in IMAP Using Outlook 5
K outlook 2003 address book Using Outlook 25
J Outlook 2003 freezing when clicking on TO button Using Outlook 2
