share one record for autodiscover between exch 2007 and exch 2010
atcnf2008
Hi, Everybody,
Our system: 1 AD, Exchange 2010 CAS array sp1(cas2010) and exchange 2007 sp2 (cas2007), to save cost, currently we only use SRV DNS record for exchange 2007 autodiscover and it's working: for IPAD/Iphone and Outlook anywhere. Now I plan to move some users to Ex2010 servers, can I just use the same SRV DNS record (which is cas2007.domain) for both Exchange 2010 users and exchange 2007 users? if I buy autodiscover.domain SSL certificate for cas2010, it will be good for 2007 users too? becuase the domain is the same, I see I must share one record for autodiscover, being SRV record or autodiscover.domain. Which is better between a CAS2007 server or CAS2010 server as the autodiscover endpoint? we have no plan to get rid of EX2007 for long time, so I guess I need both certificates even the autodiscover only has one entry point to outside devices. Thanks for any suggestions.
Sembee [MVP]
Autodiscover will work with both versions, because it queries the domain for the information for the user.
The cost savings of using SRV records are minimal - you can get a UC certificate for less than $80 a year. http://CertificatesForExchange.com/
Get a 10 name certificate and put both Exchange 2007 and 2010 URLs in to it. The same certificate can then work for both servers.
Simon.
Simon Butler, Exchange MVP
Blog | Exchange Resources
atcnf2008
Thank you for the prompt reply.
I have had ssl for CAS2007 long time ago and still valid, do I gain anything if I replace its SSL with a new SAN SSL? I don't see the point why cas2007 should be included as part of new SAN certificate, I'm confused. Thank you for any suggestions.
Sembee [MVP]
SSL is more than just OWA. If you using Outlook 2007 or higher then web services are used by Outlook to connect to the server. While you can use a self generated certificate this can cause certificate prompts, and therefore a commercial certificate is recommended.
I tend to have all client facing systems in the certificate so that there are no issues with the SSL certificate support no matter which server is used.
P Outlook 2013 Word Share doc as Email Attachment now brings up Eudora. Using Outlook 1
S automate save the .xlxs file to share Network Using Outlook 1
R Can't Send calendar share invite Using Outlook 5
G Unable to dismiss reminders from share point list calendar shared in Outlook Using Outlook 2
R Making Outlook default client in share charm Using Outlook 4
Miquela I need to make a calendar to share here at work with 40 other people Using Outlook 1
Fozzie Bear Wishlist To be able to add a local folder or network share location in foldern view Outlook Wishlist 1
smokiibear Share Office 365 Tasks such that Other Users also Are Alerted with Reminder Using Outlook 1
T How to share Outlook SUBfolders Using Outlook 3
C Moving BCM Database to Server Share BCM (Business Contact Manager) 1
J Share calendar but don't share categories Exchange Server Administration 1
D can you share a bcm database with 2 different versions of windows? BCM (Business Contact Manager) 0
L Can't share email folders Exchange Server Administration 1
K Outlook keeps prompting for Microsoft username and password for share calendar Using Outlook 0
L Archive Shared Folders for all to Share Using Outlook 0
R Share mailbox issue Exchange Server Administration 0
B Is there a simple way to share email folders w/o exchange server? Using Outlook 0
C How do I share/post my calendar to public folders Exchange Server Administration 3
A Share recurrent events with others Using Outlook 2
P Created new profile, how do I share existing contacts/calendar? Using Outlook 1
S Can't share contacts in Outlook on MS Exchange Server??? Exchange Server Administration 1
S Share between 2000 and 2010 Using Outlook 3
R Disable request to share a calendar Using Outlook 1
S share Outlook folders with other old versions Using Outlook 1
H Cannot share calendar, global address book not updating Exchange Server Administration 1
P Share Outlook 2011 Calendar Using Outlook 2
R Best way to share outlook calendar with 10 laptops Using Outlook 9
R Share ost between connector and exchange cache mode = "everything everywhere" Using Outlook 3
L How to share contacts stored in Outlook 2007 for other user. Using Outlook 2
à Loss the file share witness of DAG Exchange Server Administration 4
G Share calendar between two Outlook 2010 OR 2007 without exchange where both users can make appointme Using Outlook 1
M Share or Copy Calendar from one user to the other Using Outlook 1
M download emails and share with multiple users on Outlook 2003 while holding read and flagged status Using Outlook 2
M Share my Calender is not available in my Outlook 2007 Using Outlook 3
F Error preparing to share contacts Using Outlook 1
T How do you share an address book from a mac with a PC? Using Outlook 4
S Can't share calendar out Using Outlook 3
S Me and my big mouth...I said to my customer a district nursing organization down here in New Zealand, that 2 ipaqs should be able to share the same Co Using Outlook 1
P Can I share or copy my Outlook/BCM Custom Views with another non-Exchange user? Using Outlook 1
B Use POP3 for mail, but share Exhange calendar - not personal folder calendar Using Outlook 3
M Share Contacts greyed out in Outlook 2010. Using Outlook 1
C How to share only out-of-office appointments from my calendar to a group's shared calendar. Using Outlook 1
H Share calendars without Microsoft Exchange Using Outlook 6
P Cannot save new Outlook 2007 message as a Word template to share Building Blocks/Quick Parts Using Outlook 2
D Outlook PST file on DFS share Using Outlook 4
R DAG File Share Witness Permissions Exchange Server Administration 5
J Can multiple exchange users share same categories? Exchange Server Administration 4
J Moving File Share Witness to another server Exchange Server Administration 7
