Exchange 2010 - Active Sync issue - Samsung Galaxy S
sabo_e
We are having an activesync problem with calendaring on an Samsung Galaxy S handheld. We are at Exchange 2010 Rollup Update # 4 on all Exchange server within our environment. Has anyone seen this issue with this phone?
G
Gravey80
check what mobile policies you have enabled. Android native ActiveSync is not particuarly good and supports hardly any of the policies. You might be better off with something like TouchDown, which is a 3rd party app, until Google get their act together.
What's even dumber about Android is the setting, "Allow non provisioned devices" policy is interpreted to mean that the device does not need to enforce a password - even if the enforce password policies are set!
James-Luo
Please browse the “Microsoft-Server-ActiveSync” virtual directory, the expect error feedback is “501/505” on the webpage
Does the same symptom on other mobile device, like window mobile phone? Please verify the ActiveSync functionality with windows mobile emulator and Remote Connectivity Analyzer
If the issue happens in the emulator, please increase the diagnostic logging on the ActiveSync component, reproduce the issue, and then check the event in the application log
Please reproduce the issue, and then post the HTTP traces in the IIS log
Please enable the logging in the emulator. In the “ActiveSync” folder on the device, please check the trace in the CtrlLog0 file
1. Start, point to Programs, and then click ActiveSync
2. Click Tools, click Options, click Server, and then click Advanced
Notes: The log is saved in text format in the Windows\ActiveSync folder
If the issue only happens on the Android, the most possible cause would be on the native Android EAS solution. Please report the issue to the device vendor and require for a update
Resources:
Windows Mobile 6 Localized Emulator Images
James Luo
J Setup mail for Exchange 2010 through Active Directory on Server 2008 R2 Standard Exchange Server Administration 3
C Active Directory error applying Exchange 2010 SP1 Exchange Server Administration 4
O Exchange 2010 Service Pack 1 Active Directory Schema Exchange Server Administration 1
F Active Sync proxying not works in a Exchange 2010/2007 Coexistence Exchange Server Administration 1
A CAS Proxying with Active Sync when migrate from Exchange 2007 to 2010 Exchange Server Administration 1
P Exchange 2010 SP1 and HTC Desire Active-Sync Exchange Server Administration 5
A Active sync problem - related to improper decomission of Exchange 2007 when migrating to Exchange 2010 Exchange Server Administration 2
T Exchange 2010 servers can't communicate with Active Directory Exchange Server Administration 4
G Error Active Sync in Exchange Server 2010 Exchange Server Administration 12
Diane Poremsky Organizational Forms Library in Exchange 2010 New Slipstick.com Articles 0
V Recover exchange 2010 edb Exchange Server Administration 2
T Renaming an Resource in Exchange 2010 Exchange Server Administration 1
P Outlook 2010 MS Exchange Calendar to Android- ical or webdav? Using Outlook 1
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
H In Exchange 2010, how to block an email containing an attachment that has foreign characters Exchange Server Administration 1
N Outlook 2010 exchange - auto-move emails from @domain Exchange Server Administration 1
V Outlook 2013 cant stay connected to exchange 2010 Exchange Server Administration 5
R Exchange 2013/Outlook 2010 Slow Startups Exchange Server Administration 8
Z Outlook 2010 client to Exchange ,,,,search not working proparly Exchange Server Administration 0
M First post -help with managing two calendars Outlook 2010 /Exchange 2010 Using Outlook 0
T Outlook INBOX emails gone back 2-3 weeks after Exchange Server 2010 Restart Using Outlook 0
C Outlook 2010, two exchange mailboxes configured.Unable to see 2ndrymeeting req Using Outlook 2
C Exchange 2010 / Emails received show with display name and not email address Using Outlook 2
S Unable to send or reeceive email in new Exchange 2010 Exchange Server Administration 0
B Sharing Multiple Outlook 2010 Calendars (Exchange) Exchange Server Administration 4
P can't set IRM configuration in Exchange 2010 Exchange Server Administration 2
B Using hosted exchange to sync outlook 2010 calendars and contacts to BB Z10 Using Outlook 4
S Outlook 2010/Exchange 2010 Multi Mailboxes (Server unavailable) Using Outlook 6
D why do exchange contacts not sync properly from outlook 2011 to outlook 2010 Exchange Server Administration 2
J Exchange 2010 free/busy shows hashmarks in scheduling tab when not organizer Exchange Server Administration 6
C Exchange 2010 - Outlook 2010 - Exchange Server Administration 4
Fozzie Bear Outlook 2010 wont remember Exchange Credentials on log off /shutdown of Win7 Exchange Server Administration 2
T Exchange 2010: 'could not save item' and 'Unknown error' when edit calendars Exchange Server Administration 1
I Shared Contacts in Outlook 2010 and Exchange Server 2010 Using Outlook 4
J OL2003 Public Folder Sync Errors w/ Exchange 2010 Exchange Server Administration 11
B Outlook 2010 won't configure exchange account, 0kb .ost file Exchange Server Administration 5
R Thousand of sync issues on Outlook clients with Exchange 2010 Exchange Server Administration 5
R Create a contacts list on Exchange 2010 Exchange Server Administration 10
T Exchange / Outlook 2010 - How to cancel meetings but retain the calendar entry Using Outlook 4
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
