Public Folders move from EX2007 to EX2010
Y
yoyoyoma
Hi what would be the best process to move our public folders from EX2007 to our new Ex2010sp1 server?yoyoma
Tom Vanopoulos
You can create the Public Folder database and replicas on the Exchange 2010 server. Then replicate Public Folders over from 2007 to 2010. Replication might take a while to fully replicate all the information to the 2010 server.MCITP: Enterprise Messaging Administrator 2007/2010 | MCITP: Server Administrator | MCTS: Windows Server 2008 Applications Infrastructure, Configuring | MCP | MCDST
TWHarrington
To give a little more info. Once you create the PF database on 2010, the heirarchy will automatically replicate. You should be able to open the PF console from the toolbox on 2010 and see the PF folder structure. Once this is done, you can add the 2010 server as a replica to all folders by running this script:
C:\Program Files\Microsoft\Exchange Server\V14\Scripts>
.\AddReplicaToPFRecursive.ps1 -TopPublicFolder "\" -ServerToAdd "exchange2010"
You can check the replica list by running: Get-PublicFolder -Recurse | Format-List Name,Replicas
Once everything is replicated and you are ready to remove the PF replicas from 2007, you can run:
.\MoveAllReplicas.ps1 -Server "Exchange2007" -NewServer "Exchange2010"
S auto move mails from mailboxes to public folders Exchange Server Administration 6
C Outlook 2016: Searching in all (+public) folders Outlook VBA and Custom Forms 9
L Public folders permissions Exchange Server Administration 1
Diane Poremsky Mail-enable Exchange Public Folders New Slipstick.com Articles 0
J Favorites in Public Folders issue Outlook VBA and Custom Forms 0
V Macro to open Public Folders subfolder? Outlook VBA and Custom Forms 1
M Codetwo Public Folders structure for vba Outlook VBA and Custom Forms 13
E Outlook 2007 Saves .MSG E-Mails with attachment from Public Folders as RTF Using Outlook 0
C How do I share/post my calendar to public folders Exchange Server Administration 3
T managing contacts in public folders Using Outlook 4
C Custom form with custom colour category visible to all users in public folders Using Outlook 1
L Public folders suddenly gone in outlook 2k7 Using Outlook 1
K Clearing/Deleting all Public Folders through VBA Using Outlook 3
J Change the subject line of messages in public folders Using Outlook 3
J Public folders woes (script to change subject line of messages) Exchange Server Administration 0
B Initial "Connecting" to public folders on startup Using Outlook 8
Z update individuals in public folders Outlook Wishlist 1
Z update individuals in public folders Exchange Server Administration 1
B Permissions - Outlook Public Folders Are Being Deleted Using Outlook 1
R public folders Using Outlook 2
T Public folders in outlook 2010 Using Outlook 1
R Change Public Folders Label in Folder List Using Outlook 1
B Public Folders Replica(s) - is there only one if there are multiple sites? Exchange Server Administration 6
V Uninstall ONLY Exchange 2010 but leave Exchange 2003 server in place - Public Folders Question Exchange Server Administration 5
I outlook unable to view public folders and autodiscovery not working Using Outlook 1
H Exchange 2003 to 2010 Transition, Public Folders Exchange Server Administration 2
R Unable to use Public Folders on Exchange 2007 via OLK2007 Using Outlook 2
I Public Folders not replicating between Ex 2003 and Ex 2010 Exchange Server Administration 7
J Why did the relative root path of the Exchange public folders change from \\Public Folders\All Publi Exchange Server Administration 1
T Exchange 2010 Public Folders Database Size Discrepancy Exchange Server Administration 4
B Searching across public folders in EXCHANGE 2007 Exchange Server Administration 2
S Exchange 2007 public folders issue (calendar items) Exchange Server Administration 2
M Public Folders Not Replicating Between Exchange 2007 and 2010 (Migrate/Transitioning 2007 to 2010) Exchange Server Administration 6
S Exchange 2003 transition Public Folders Exchange Server Administration 2
N Are public folders required in Exchange 2010? Exchange Server Administration 3
A Are Public Folders Contacts available through activesync for Windows Phone 7, Iphone, etc? Exchange Server Administration 3
J Public folders in Exchange 2010 - require Sharepoint? Exchange Server Administration 3
S Views on frequently updated public folders in Outlook 2003 for many users Using Outlook 1
J Outlook 2010 - Public Folders difficult to access after adding multiple additional mailboxes into th Using Outlook 4
P Outlook 2011 Does not Sync Public Folders (Exchange 2007) Using Outlook 2
M Public Folders in Exchange 2003 not available in Exchange 2010 Exchange Server Administration 11
2 Moving Public Folders to Resource Forest Exchange Server Administration 2
J I cannot view public folders in Microsoft Outlook 10. We are using exchange server. Can someone help me? Thanks. Using Outlook 1
T Exchange 2010 public folders cannot be opened from Outlook, but can from OWA Exchange Server Administration 2
C System Public Folders Missing Exchange Server Administration 2
