Autodiscover virtual directory - recreation fails
  • Thread starter Recreate autodiscover virtual directory
  • Start date
Hallo together,
because autodiscover wasn't working proberly i tried to delete and recreate the autodiscover virtual directory:
Remove:
C:\Windows\system32>Remove-AutodiscoverVirtualDirectory -Identity " SERVER1\Autodiscover (Default Web Site)"
Recreate:
[PS] C:\Windows\system32>New-AutodiscoverVirtualDirectory -WebsiteName " Default Web Site"
-WindowsAuthentication $true - 02. BasicAuthentication $true
Then i get the following error:
The Active Directory object for virtual directory 'IIS://server.domain.com/W3SVC/1/ROOT/Autodiscover' on
'SERVER' could not be created. This might be because the object already exists in Active Directory.
Remove the object from Active Directory, then re-create it. + CategoryInfo : InvalidOperation: (DAEDALUS\Autodiscover (Default Web Site):ADObjectId)
[New-AutodiscoverVirtualDirectory], InvalidOperationException + FullyQualifiedErrorId :
804814BA,Microsoft.Exchange.Management.SystemConfigurationTasks.NewAutodiscoverVirtualDirectory
However, there is no autodiscover virtual directory in IIS, i tried to find it via Metabase Explorer with no success.
It is an Exchange 2010 std SP1 with w2k8 R2 in a two-server DAG (may be that is the problem).
N
Novak Wu
This issue can occur if Autodiscover object is not removed completely in Metabase. To troubleshoot the issue, please locate the IIS configuration file and manually remove Autodiscover object. The IIS configuration files are located in ApplicationHost.config. This file is located in %windir%\system32\inetsrv\config. You can back up the file to other location first. Then, found the <application path=Autodiscover> entry and remove them.
For more information, please refer to the following article:
http://social.technet.microsoft.com/Forums/en-US/exchangesvrclients/thread/d9a71111-6c67-495e-b1dc-1524378d23c2
Novak Wu
S Exhcange 2010 autodiscover virtual directory Exchange Server Administration 4
L Reinstall IIS / Autodiscover virtual directories on an computer running Exchange 2010 server? Exchange Server Administration 6
B AutoDiscover Forensics Exchange Server Administration 0
EXChange2013 Exchange 2013 AutoDiscover Tweaks? Exchange Server Administration 0
M Outlook 2007 AutoDiscover Using Outlook 0
A Exchange Autodiscover SSL issue Exchange Server Administration 7
M Initial Outlook Configuration with AutoDiscover populates wrong email address Using Outlook 5
N Outlook 2007 Clients Pointed to Wrong Domain Name for Autodiscover Using Outlook 2
K testing autodiscover and exchange coexistence Exchange Server Administration 2
C The Autodiscover service couldn't be located. Exchange Server Administration 8
C Exchange server 2010 error "The Autodiscover service couldn't be located." Exchange Server Administration 1
J Autodiscover accounts on exchange 2003 with Outloook 2010 not working Using Outlook 4
Z Autodiscover Points to defunct Exchange 2010 Server Exchange Server Administration 5
M Autodiscover not configuring Outlook Anywhere Using Outlook 10
B Autodiscover error 0x800c8203 and encrypted connection is not available Exchange Server Administration 3
P Autodiscover URLs Exchange Server Administration 15
C Autodiscover Exchange Server Administration 6
I Exchange 2010 Profile AutoDiscover not working for some users Exchange Server Administration 1
D External Autodiscover Exchange Server Administration 3
S Exchange 2010 Autodiscover Problems, cannot connect Outlook clients using Autodiscover / Outlook Any Exchange Server Administration 4
G Exchange 2010/Outlook 2007 Can't get autodiscover to work for some users, but others work fine Exchange Server Administration 3
S Autodiscover issue Exchange 2007 Using Outlook 4
P Autodiscover will not work Exchange Server Administration 13
K Exchange 2010 Autodiscover Exchange Server Administration 1
P Autodiscover fails (Exchange 2010) Exchange Server Administration 7
P Autodiscover issues on Exchange 2010 Exchange Server Administration 7
S Exchange 2010 Outlook 2010 Autodiscover fails Exchange Server Administration 22
C Getting Autodiscover to work with other web servers ... Using Outlook 4
C Autodiscover Service Configuration Exchange Server Administration 5
B move mailbox- autodiscover Exchange Server Administration 25
T Autodiscover authentication Exchange Server Administration 2
A autodiscover issue with OL2010 but no issue with OL2007 Exchange Server Administration 10
K Autodiscover and SRV records Using Outlook 10
S Autodiscover redirected Using Outlook 2
C Autodiscover Exchange Server Administration 5
S Autodiscover two AD sites two cas arrays Exchange Server Administration 4
O Autodiscover Exchange Server Administration 4
S Autodiscover FQDN certificate for secondary domain email? Exchange Server Administration 1
K Remove AlternativeMailbox - Autodiscover Exchange Server Administration 5
S Exchange 2010 autodiscover Exchange Server Administration 4
A share one record for autodiscover between exch 2007 and exch 2010 Exchange Server Administration 4
O SSL certificate needed for autodiscover.domain.com Exchange Server Administration 12
