Some Outlook clients not opening (2003/2007/2010) but no apparent issue with mailboxes
Ben Grinsted
We're currently in the throes of transitioning to Exchange 2010 and are running with a 2003/2007/2010 coexistence. We haven't had any problems until yesterday when a number of users who have been moved to 2010 were unable to open Outlook and it comes back with an error saying: Either there are network problems or the MS Exchange Server Computer is down for maintenance. This can be with any client, 2003, 2007, 2010. Outlook Web App works just fine and occasionally a clean client with fresh profile will work.
I thought that it might be to do with the encrypted traffic, however this box is checked and they were able to open their mailbox via Outlook the day before. I tried turning off encryption to the CAS entirely and that didn't make a spot of difference. There aren't any DNS problems as far as I can see and given that OWA works pointing to the same server, that wouldn't make sense.
Having searched extensively, the only solutions I can find are when you can't access a mailbox from ANY Outlook client, rather than some working. Therefore these solutions haven't worked or just don't apply. I haven't been able to find anything where the problem isn't as clear cut.
Any help appreciated!
P
Pano Boschung
Hi Ben
It seems that Outlook was unable to change to the new Exchange Server.
Did you try to open the Outlook profile, and then set the new Exchange Server manually?
Regards
Pano
Pano Boschung, PageUp AG
Ben Grinsted
Hi Pano,
I did think about that also and have manually set the new CAS Array in there, but still no luck. This has also started happening where it was working previously, so I'm not sure it's due to this reason.
Ben
P
Pano Boschung
Hi Ben
If you try to create a new Outlook profile does it work?
Regards
Pano
Ben Grinsted
In the end we reissued the Exchange certificate and included the legacy/autodiscover options when issuing the request and this appeared to be what fixed it.
Not entirely sure if it was that, but it's working now.
Thanks for you help,
Ben
J Outlook 2007 Clients Prompt For Password When Opening Using Outlook 21
blashmet Outlook Signature Distorted in Other Email Clients Using Outlook 9
R Thousand of sync issues on Outlook clients with Exchange 2010 Exchange Server Administration 5
S New Outlook 2003 Clients with Existing Exchange 2010 error's Exchange Server Administration 6
X Exchange 2007 Outlook Anywhere Clients unable to retrieve GAL Using Outlook 9
N Outlook 2007 Clients Pointed to Wrong Domain Name for Autodiscover Using Outlook 2
J Post SP3 upgrade - outlook 2003/2010 clients cannot connect Using Outlook 1
A cannot connect outlook 2007 clients to exchange 2010 Exchange Server Administration 3
C Outlook 2010 with BCM - Database Connection problems using Windows 7 Clients Using Outlook 1
N Outlook 2010 Clients can't reply to emails or download offline address book? Hosted Exchange 2007 Using Outlook 5
D Upgraded to Exchange 2010 SP1 and now random Outlook clients are requesting authentication Exchange Server Administration 1
S Exchange 2010 Autodiscover Problems, cannot connect Outlook clients using Autodiscover / Outlook Any Exchange Server Administration 4
B Mac clients using Entourage and Outlook experiencing delayed email Exchange Server Administration 20
R how to configure outlook 2007 clients to publish free busy info to public folder in exchange 2010 (s Exchange Server Administration 3
G How to enable Outlook Anywhere for domain joined clients, enable Exchange ActiveSync, but disable OA Exchange Server Administration 1
C outlook clients prompt for a password each time it open Exchange Server Administration 2
M Will Outlook 2002 clients break when upgrading domain to 2008R2? Using Outlook 5
M exchange 2007 and xp clients using outlook in nt4 domain Using Outlook 1
A What are the known sharing issues with Outlook 2003 clients and Outlook 2010 clients on the same network? Exchange Server Administration 3
A What are the known sharing issues with Outlook 2003 clients and Outlook 2010 clients on the same network? Using Outlook 1
M Does a shared Outlook BCM 2007 database work with both Outlook BCM 2007 and 2010 clients? Using Outlook 2
C Reboot a CAS array member causes Outlook 2010 clients to prompt for credentials. Using Outlook 5
D Exchange 2010 and outlook clients mails delays/delete and other problems Exchange Server Administration 9
C Prevent clients outlook anywhere URL from being changed by autodiscover? Using Outlook 4
K Exchange 2010 Archive support Outlook clients? Exchange Server Administration 9
J Outlook clients get "Contacting the server for information" Exchange Server Administration 7
P outlook 2008 search box criteria couldn't be saved Using Outlook 1
pcunite Outlook 2019/O365 Build 13127.20408 errors when using MAPI calls Using Outlook 0
D Outlook 2010 Outlook in Windows 10 keeps asking for user name and password repeatedly Using Outlook 5
J How do I disable advertising in Outlook 2019? Using Outlook 5
B Outlook Calendar not coming down from cloud Using Outlook 2
