Best practices for creating "Equipment" mailbox resources?
Romseye
Using single a Exch 2007 Ent server on Server2008 R2. Have a single domain with 3 separate entities, each in a separate OU in AD. Would like to a way to create separate " Equipment" address lists, that are only available to the corresponding users in each separate OU. Is the best way to achieve this by creating a new address list in Exch Console->Organization Configuration->Mailbox? If so, I'm unsure as to how to set permissions so only users in an OU can only see their equipment address list. Appreciate any ideas/pointers.
S CAS/MBX reboot best practices. Exchange Server Administration 7
R Any "Best Practices" for a test/developer Exchange 2010 server? Exchange Server Administration 2
M Exchange 2010: What to monitor - best practices Exchange Server Administration 4
Rupert Dragwater What is the best way to back up pst Using Outlook 4
Diane Poremsky The Best Outlook Store Add-ins Contest New Slipstick.com Articles 0
X Best utility for repairing PST files? Using Outlook 3
D a suggestion ...sent with the best intentions Using Outlook 1
M How best to track OUTGOING referrals? BCM (Business Contact Manager) 2
M best duplicate contact remover? Using Outlook 6
G what is the best way to organize outlook contacts Using Outlook 1
D What would be the best strategy? Using Outlook 3
J Best way to move form old to new, larger pst? Using Outlook 2
M Best way to move outlook? Using Outlook 1
R Best way to share outlook calendar with 10 laptops Using Outlook 9
Horsepower Email best practice Using Outlook 3
N Outlook 2010, Categories, best way to filter contacts? Using Outlook 5
F Best Non MS Exchange 2010 book for beginners? Exchange Server Administration 7
I Best Practice for Large Messages NDRs? Exchange Server Administration 4
L best rule/macro to send emails from many people/orgs to same folder Using Outlook 3
C Best way to effectively back up Outlook Calendar (and save Categories) and Email as well???? Using Outlook 6
D Exchange Best Practice for DEV/TEST/PROD Exchange Server Administration 2
K Best case scenerio to reduce disk space usage Exchange Server Administration 5
B Best way to get a pick-list on a form? Outlook VBA and Custom Forms 1
M Best way to distribute VBA project Outlook VBA and Custom Forms 4
T Is Explorer.FolderSwitch the best event for hiding commandbarbutton? Outlook VBA and Custom Forms 5
R Creating a user defined function Outlook VBA and Custom Forms 3
