outlook 2007 not printing body of emails
bob joe bob joe
running xp, outlook 2007, ms office 2010
when trying to print emails from outlook 2007, the header of the email will print [the from, cc, bcc, to, subject] but the body of the email [the message being sent] is not printing. this happens occassionally. the only solution that i have found is to restart my computer when it does happen and print it again [and it prints fine].
bob joe bob joe
Do you have all updates for Outlook 2007 installed?
yes. i did the windows update as well.
V
Vinay - G
What is the mail format which you are trying to print?
Does this happen only with outlook or other office applications also?
Change the default printer and check if it helps:
Click on start->printer and fax->Right click on XPS document writer and set it as default.
Try printing and check if it prints the body of the email also .If it prints then get in touch with the printer manufacturer and update the printer drivers.
G booklet printing in outlook 2007 Using Outlook 1
P Printing Issues in Outlook 2007 Using Outlook 1
R How do I use Outlook 2007 for printing a label list for a specific category Using Outlook 3
P Outlook 2007 - Printing same barcode on all the emails though email contains different barcode Using Outlook 3
B Outlook 2007 Calendar Printing with large font Using Outlook 1
I Outlook 2007 Crashes When Printing or going to Print Preview Using Outlook 3
S Printing from Outlook 2007 only prints to default printer. Using Outlook 1
S Outlook 2007 Calendar Printing Assistant-Erron Printing Tasks Using Outlook 1
A Outlook 2007 Calendar month view printing with word wrap - cutting words in the middle Using Outlook 5
N Outlook 2007 Monthly Calendar printing without meeting details. Using Outlook 5
D Printing Multiple Attachments Outlook 2007 Using Outlook 1
Diane Poremsky Manually create a POP3 account in Outlook 2007 New Slipstick.com Articles 0
R Outlook 2007 - Shared Accounts and Resources without Exchange Server Using Outlook 0
