Email attachments will not open in outlook nor will they open if I save and try to open. They are sh
C
crahn1
Attachments open in wingdings. It appears with a old program that is no longer on my system.
Why type of documents are they, what file extension? Are they opening with the wingdings font or was there a program called wingdings previously installed? If you save the file to your computer, right click on it and choose open with... and choose the correct program, does it work correctly?
B Web-based email attachments won't open in Office 2010 Using Outlook 5
P Can't open attachments in body of email in Outlook 2010. Using Outlook 4
M RECENTLY UPGRADED FROM HOME & BUSINESS to OFFICE PRO - CANNOT OPEN ATTACHMENTS DIRECTLY FROM EMAIL Using Outlook 1
P Cannot open .jpg from email attachments Using Outlook 6
Dan_W Nested email attachments Outlook VBA and Custom Forms 4
G Download pdf attachments only if email subject has one of words Outlook VBA and Custom Forms 8
I Forwarding attachments in email received Outlook VBA and Custom Forms 3
C Rule To Save attachments on receipt of email Outlook VBA and Custom Forms 2
Diane Poremsky Add Attachments and Set Email Fields During a Mail Merge New Slipstick.com Articles 0
Diane Poremsky Add attachments and set email fields during a mail merge to email New Slipstick.com Articles 0
S Attachments to New email item Using Outlook 1
L Auto printing unread email + attachments in Inbox - Outlook 2010 - (New user) Using Outlook 1
C Visual Basic auto create task from email including attachments Using Outlook 9
G archive attribute for email attachments Using Outlook 2
H outlook email merging with attachments Using Outlook 4
R BCM: Email attachments are not shown BCM (Business Contact Manager) 4
M Outlook 2010 and how to get attachments listed when creating a new email? Using Outlook 1
M Change default program for opening email attachments. Using Outlook 1
P Outlook 2007 won't send email with attachments Using Outlook 2
B Outlook 2011 email attachments Using Outlook 1
A When forwarding attachments, the email address of recipient is lost Using Outlook 2
A outlook keeps files sent as attachments locked after email has been sent... Using Outlook 3
R Email attachments in Outlook 2007 Using Outlook 1
V Outlook 2010 - attachments with mail merge email Using Outlook 4
C MS Outlook 2007 - UTF-8 characters are not properly shown in email attachments Using Outlook 1
G opening attachments from an email closes the program and restarts outlook 90% of the time Using Outlook 2
B Recipient is Missing email attachments Using Outlook 2
T "The Operation Failed" When opening file attachments on an email. Using Outlook 1
K Forwarding an email with Attachments Using Outlook 3
N Cannot hear audio in email attachments on outlook 2010 Using Outlook 3
J Exchange 2010 - Email attachments sending to multiple userts Exchange Server Administration 3
G Re: Outlook 2007 email attachments Using Outlook 3
R OWA 2010 SP1 Email sent to OWA 2003 attachments missing Exchange Server Administration 20
C Attachments come across as win.dat files to receiver. Attachments end up in the body of the email, not at the top as an attachment. How can this be Using Outlook 1
B OE6 Opens *.eml attachments as Outlook 2010 Email even though OE is default. Using Outlook 2
L Changing where Outlook 2010 automatically saves email attachments Using Outlook 1
C Tried to send an email with attachments that were too large and not it is 'stuck' in my outbox. Using Outlook 1
C Saving email including attachments Using Outlook 4
5 Automatically print email attachments Using Outlook 7
R Auto Reply with Original Email and any attachments Outlook VBA and Custom Forms 1
K Mail Merge to email with attachments Outlook VBA and Custom Forms 8
H Storing an email along with its attachments? Outlook VBA and Custom Forms 1
