Outlook 2003/2007/2010 not showing attachments but OWA does
mike_coreit
I have recently moved from exchange 2004 to 2007. I am connecting to this with outlook 2003 and am receiving emails but I cannot receive pdf attachments from a specific sender. I can see these attachments in OWA but not in the outlook client.
I called the organisation responsible for sending these emails but they said its down to a bug in outlook where the MIME type is not handled correctly.
I have tried viewing the emails on a 2007 client and a 2010 trial version but the same thing happens. Interestingly when I import the emails into Mozilla Thunderbird the attachments appear as they should.
mike_coreit
Is there a way to sort this out from the server end instead of installing this software on each pc?
mike_coreit
I don't plan on running this tool to extract every single attachment from my mailbox. Is there a way to extract the attachments for just a selected message?
mike_coreit
I managed to find a work-around anyway. I figured the old set-up had these specific emails going through a pop3 mailbox for a reason - I have replicated this and it has solved my problem.
D outlook 2003/2007 macro query Using Outlook 2
D Calendar Permissions Outlook 2003, 2007 and 2010 Exchange Server Administration 2
G Is there any way to convert outlook 2003 to outlook 2007 Using Outlook 5
D Outlook 2007 contacts do not show up in address book - 97-2003 pst file Using Outlook 0
J Outlook 2003/2007 IMAP emails dont show in inbox Using Outlook 0
K Outlook 2007 vs Outlook 2003 Using Outlook 1
P Exporting Calendar, Contacts & Tasks from Outlook 2007 to Outlook 2003 Using Outlook 5
J Outlook 2003 can not find Global Address List after downgrading from Outlook 2007 Using Outlook 1
V Outlook Connector not syncing to Outlook 2003 AND 2007 Using Outlook.com accounts in Outlook 1
M Outlook Mail Format Options - Grayed out 2003 office/outlook in exchange 2007 mail organisation. Using Outlook 3
D Upgraded from Outlook 2003 to Outlook 2007 lost my secondary contacts list Using Outlook 1
C Uninstalled Office 2007 and installed Office 2003. Unable to work with Outlook. Using Outlook 5
P Outlook 2007 on Exchange 2003 - Meeting Organizer not seeing new proposed time from external parties Using Outlook 5
M Can't open a link within email using outlook 2003. My laptop is windows office 2007. Using Outlook 1
N Exchange 2003 Outlook 2007 Outlook anywhere timeout Using Outlook 3
R Windows 7 Pro + Outlook 2003 or Outlook 2007 + Exchange 2003 = RPC over HTTP doesn't work Using Outlook 6
D Can I open an Outlook 2010 pst file in Outlook 2003 or Outlook 2007? Using Outlook 4
B Switching Access from version 2010 to 2007 or 2003 causes Outlook to no longer be able to send or receive email. Using Outlook 2
B Undeliverable on internet meeting request. Exchange 2003/Outlook 2007 Using Outlook 3
F Moving Outlook 2003 to 2007/10 to a New Computer , from win xp to win 7 Using Outlook 1
M Exch 2007 / Outlook 2003 - Over message limit inconsistencies Using Outlook 1
J Exchange 2003 (SBS) & Outlook 2007 Using Outlook 1
R Outlook 2003 and 2007 Using Outlook 2
J ICS incorrect time in Outlook 2007/2010 but not in Outlook 2003 Using Outlook 2
A Outlook 2010's Meetings with Updates not showing up in scheduling for Outlook 2003 and Outlook 2007 Using Outlook 1
W When users try to setup a meeting in outlook 2007 or 2003 they will get an Undeliverable delivery st Using Outlook 1
O Outlook 2007 and loading data from Outlook/Office 2003 Using Outlook 1
S Synchronising Outlook on a laptop and desktop Office 2003 and 2007 Using Outlook 1
D Keep receiving Sending' report error (0x80042109) in Outlook 2003 & 2007 on multilpe computers thru Using Outlook 4
O Outlook 2003 and 2007 Calendar attendee issues Using Outlook 5
G Outlook 2007 defaulting to TCP/IP for connecting to Exchange 2003 on setup Using Outlook 1
K Outlook 2007/Exchange 2003 deleting emails Using Outlook 11
B Some Outlook clients not opening (2003/2007/2010) but no apparent issue with mailboxes Using Outlook 4
Y Additional line gets added while replying - Outlook 2003-2007 Using Outlook 3
P AutoArchiving setting in MS outlook 2003, 2007 & 2010 Using Outlook 1
K Outlook 2007 restart after trying to view Outlook 2003 email sent by colleague Using Outlook 2
L Outlook 2003 vc 2007 - where has Send and File gone? Using Outlook 1
T In Outlook 2003 and 2007 you had Categories for contacts. Where is it in Outlook 2010? Using Outlook 3
N trying to make express 2003 work with emails from outlook 2007 Using Outlook 2
D Exchange 2007 appointments rendering issue in Outlook 2003 Exchange Server Administration 3
M Iterating a Contacts folder for Outlook 2003 and 2007 in C# Outlook VBA and Custom Forms 8
F Outlook 2003 form cannot be loaded in 2007 Outlook VBA and Custom Forms 1
M Business contact manager 2003 on outlook 2007 BCM (Business Contact Manager) 1
K Outlook 2003 to 2007 data transfer Using Outlook 3
A COM add-in causes Outlook 2007 to periodically crash where it did not in Outlook 2003 Outlook VBA and Custom Forms 3
K Is it possible to use BCM 2003 with Outlook 2007? BCM (Business Contact Manager) 4
S Can Outlook 2007 calendar match the Outlook 2003 calendar? Calendar Printing Assistant 3
U Installing Outlook 2003 instead of 2007 Calendar Printing Assistant 2
C Outlook 2003 Add-in doesn't work on Outlook 2007 Outlook VBA and Custom Forms 1
