Outlook 2007/2010 stays in 'Trying to connect' mode when mode of connectivity changes from LAN to HS
K
K. Phani Kumar
Hi All,
I have more than 40% of the users who connect to Exchange Server through RPC Over HTTPS using internet as medium. Many of the users have complained that when they disconnect their Outlook from LAN and try to reconnect using some High Speed Internet Access (HSIA) connectivity, Outlook just says " Trying to connect" and does not automatically detects the new network connectivity and gets connected to Exchange Server. It does not ask for authentication window also.
Once the Outlook is closed and re-opened, it asks for authentication and on successful login, it gets connected successfully to Exchange at the first instance. Is this an issue which can be resolved or it is a known issue/behaviour of MS Outlook?
Please suggest, as many of the Senior Management Users are complaining from our Client side. Thanks in advance for your support.
Regards, K Phani Kumar IT Analyst Windows & Messaging Tata Consultancy Services
H
Harry Yuan
Are all the users experiencing the same issue when connecting RPC Over HTTP? Did you check this issue on another computer?
If this issue only occur on the special computer, that should be the client issue. You need to confirm the connection status of the Outlook 2010.
Press Ctrl+right click Outlook icon in System Tray, select Connection Status, check which type of connection is trying to connect.
Regards,
Harry
P How to switch back from Outlook 2010 to Outlook 2007? Using Outlook 3
E Upgrade Issues - Office/Outlook 2007 to 2010 Using Outlook 0
Z Copy Outlook 2007 "AutoComplete Contacts” to Outlook 2010 Using Outlook 7
M Messages Held in Outbox 2007 Outlook 2010 Using Outlook 1
V Outlook 2007/2010 - First time iCloud setup and config for heavy Outlook user Using Outlook 1
V Outlook 2007 vs Outlook 2010 on Windows 8 Using Outlook 18
G Outlook 2007 in Outlook 2010 asks for password Using Outlook 2
T Syncing OWA 2010 to Outlook 2007 Exchange Server Administration 15
M Searching Outllook 2010 shared contacts from Outlook 2007 Using Outlook 4
D Calendar Permissions Outlook 2003, 2007 and 2010 Exchange Server Administration 2
H Conflicts with other event in calendar ( outlook 2007 & 2010) Using Outlook 0
S Missing Color Categories Outlook 2007/2010 Using Outlook 2
J Move PST /changing default location in Outlook 2007 or 2010 64b on W7 64bit Using Outlook 2
I Send Secure Email Through Microsoft Outlook 2007 and 2010 (32 bit) Using Outlook 0
B Outlook 2007/2010 not downloading the OAB Exchange Server Administration 0
D Outlook 2007 & 2010 calendar permissions Using Outlook 2
S Calendar sharing problmes between Outlook 2007 & 2010 Exchange Server Administration 0
J Outlook 2007 and 2010 for multiple calendar users Using Outlook 1
D Inviting attendees Outlook 2010 and Outlook 2007 Using Outlook 5
D Outlook 2007 December 14 2010 (KB 2412171) Update Fix Using Outlook 0
S Outlook 2010 Journal does not record activities on Office 2007 files Using Outlook 1
D Outlook 2007 Slow Since Office 2010 Installed Using Outlook 1
P I have Outlook 2007 on a two year old computer running Vista. How do I copy my Outlook Contacts list and move them over to Outlook 2010 on a brand new Using Outlook 1
B Outlook 2007 New email notification works intermittently after adding Exchange 2010 Servers Exchange Server Administration 1
M Outlook 2010-Sync with Exchange server 2007 Using Outlook 2
W Unable to sync Outlook contacts and calendar since upgrading from Outlook 2007 to Outlook 2010 Using Outlook 1
J Suggested times does not work with Outlook 2010 in combination with Exchange 2007 SP2? Using Outlook 2
M Outlook 2010 Connectivity with Exchange 2007 Using Outlook 5
J After Window update of 12/15/2010, outlook 2007 gives error (0x800CCC18) when accessing gmail using Using Outlook 6
T SharePoint 2007 MySites and Outlook 2010 Social Connector Using Outlook 1
K Outlook PST file created in 2010 can be used in 2007? Using Outlook 2
M Outlook 2010 Connectivity with exchange server 2007 Using Outlook 1
A cannot connect outlook 2007 clients to exchange 2010 Exchange Server Administration 3
S Re: Outlook 2010 crashes when upgraded from Office 2007 Using Outlook 1
T Outlook 2010 crashes when upgraded from Office 2007 Using Outlook 1
C Outlook 2010 Trial Is Up and Now 2007 Address Books Aren't Connecting to Contacts Using Outlook 24
G Share calendar between two Outlook 2010 OR 2007 without exchange where both users can make appointme Using Outlook 1
B Blank email list views on Outlook 2010 / 2007 with Exchange 2010 SP1 (on Citrix and Desktops) Using Outlook 7
T How Outlook 2007/2010 choose which Exchange Web Service to use? Using Outlook 1
G Subscribing to Shared Outlook Calendar 2007 / 2010 from invitation leads to user name and password request. Using Outlook 2
T Re: Outlook Anywhere in Outlook 2010 and Exchange 2007 Using Outlook 3
T Outlook Anywhere in Outlook 2010 and Exchange 2007 Using Outlook 1
