Edge transport and TMG best practice NLB
K
KirkSH
What is the general opinion on setup for Edge and TMG. Is it better to have 2 Edge transport servers with two mx records in our DNS or two Edge Transport servers connected via NLB and one mx record in our DNS? Along with that is TMG as a reverse proxy work well with 2 TMG servers connected via NLB? Thanks for your help.
E
Ed Crowley [MVP]
In addition to your options, you can now have TMG and Edge 2010 on the same server.
I don't think I'd deploy NLB, though I'd consider hardware load balancing. I don't even know if it's supported with TMG. If you put TMG in front of Edge (on separate servers) you'd want to use a server farm instead of NLB for the Edge servers, I think.
Ed Crowley MVP " There are seldom good technological solutions to behavioral problems."
S Edge Transport 3rd party mail filter before Exchange 2010 Exchange Server Administration 5
T Prerequisites softwares for installing exchange 2010 edge transport server on windows 2008 R2 Exchange Server Administration 1
J ex2010 edge transport - inbound from internet Exchange Server Administration 7
R Exchange 2010 Edge Transport server not passing emails... Exchange Server Administration 7
P Exchange 2010 Edge Transport Delays mail Exchange Server Administration 5
H Setting up an Edge Transport Server - Exch 2010 Exchange Server Administration 11
Z Hub Transport and Edge is not working as it should Exchange Server Administration 12
L Plethora of Event ID FAILs on the Edge Transport Exchange Server Administration 4
L Exchange server 2010 edge to hub-transport routing error Exchange Server Administration 9
J Edge + TMG 2010 No email inbound/outbound and cannot telnet to port 25 on TMG Exchange Server Administration 0
J CPA cuts off left edge of printed Calendar. Ex. January the J is cut off. Calendar Printing Assistant 11
S Configure Exchange Edge 2010 on TMG in DMZ Exchange Server Administration 1
M join internet domain without edge server to the internal DC domain Exchange Server Administration 4
G Ex2010: Edge Sync / SynStatus Inconclusive? Exchange Server Administration 7
S Edge 2010 and Forefront 2010 in DMZ Exchange Server Administration 12
S Edge 2010 and TMG on the same box Exchange Server Administration 1
S Forefront TMG Management Control 2010 on Edge Server. Exchange Server Administration 1
S how to print all emails sent and received via edge in 2010 Exchange Server Administration 13
M Re: How to force routing between two internal smtp domains across Two Edge servers Exchange Server Administration 7
M How to force routing between two internal smtp domains across Two Edge servers Exchange Server Administration 3
K Edge to Hub to Exchange 2003 Exchange Server Administration 4
K Edge SyncStatus: Inconclusive Exchange Server Administration 2
N Exchnage 2010 Hub Cas Edge Server Recovery Exchange Server Administration 3
K Edge Hub testing Exchange Server Administration 10
A Hub 2010 to Edge 2007 ( Last Error: 421 4.4.2 Connection dropped due to ConnectionReset ) Exchange Server Administration 3
H Edge subscription question Exchange Server Administration 1
D exchange 2010 edge smtp authentication Exchange Server Administration 7
T Use edge servers as relay machines for application servers Exchange Server Administration 2
P Transport Agent or Rules/Connectors Exchange Server Administration 1
L Transport rule - append disclaimer Exchange Server Administration 1
G set exch 2010 server as the default hub transport Exchange Server Administration 6
S Hub transport ex2007 - monitoring inbound Exchange Server Administration 2
D How to manage and configure antispam updates for Hub Transport antispam filter agents at "filesystem Exchange Server Administration 1
P Exchange transport overheads Exchange Server Administration 4
P Exchange 2010 - Enable Spam filtering on Hub Transport Server Exchange Server Administration 3
C ms transport suite Exchange Server Administration 2
X Internal mail flow between two hub transport servers same domain Exchange Server Administration 10
C Transport Rule Exchange Server Administration 4
R Fax Transport Outlook 2010 (32-bit) Using Outlook 12
S Exchange 2010 - Mail Transport Exchange Server Administration 2
D Ms Exchange 2010 - Sp1 Upgrade at Prerequisites on Hub Transport Role Exchange Server Administration 8
T 451 4.4 dns query failed on exchange 2010 hub transport server Exchange Server Administration 1
L Transport Service Issues Message Queue keeps going offline slow mail delivery Exchange Server Administration 1
A Windows NLB for Exchange 2010 SP1 Hub Transport Servers Exchange Server Administration 7
