accessing owa externally and having a cas array internally
Roy DDDE
We have internally 2 cas servers setup in a casarray. Internally if you go to casarray.domain.com everything works fine.
I have even enabled redirection so that if you go to casarray.domain.com it redirects you to https://casarray.domain.com/owa
using these instructions from brian desmond.com
http://briandesmond.com/blog/redirecting-owa-urls-in-exchange-2010/
the issue comes when coming from the outside, i have nat'd our external ip to the internal ip of casarray.domain.com. but it redirects it to the casarray.domain.com/owa and obviously this doesnt work externally.
any help!
Aivar75
hi
how have you configured your dns have split dns or just 1.
another thing, why not to use your casarray name as external? that would work from anywhere.
atleast i did it like that, both external and internal urls are casarray external fqdn and sertificates fqdns points to that same casarray name.
plain and simple.
atleats works for me.
Sembee [MVP]
The problem is that you have used a hard URL for the redirection.
The problem outlined in that blog posting you have linked to is not something I have ever come across, because I never open port 80 inside. Users have to enter https, if they can't learn, tough. Where it has got tricky, I have put a redirect file on the public web site, (so the users can go to www.example.com/mail and it takes them to https://owa.example.com/owa ).
As indicated above, you either need to take off the redirection or make it so the redirection only occurs on https. If you lose the requirement to redirect http to https traffic, then redirect file in the root just needs to redirect to /owa, it doesn't matter what the URL is.
I also believe that using the CAS array externally is either not supported or at least not recommended. I have avoid the name resolving externally in my notes for the configuration of the feature, so I have read or experienced that somewhere. I think it will cause problems with Outlook Anywhere, as the host name for a native MAPI connection resolves then fails.
Simon.
Simon Butler, Exchange MVP
Blog | Exchange Resources
Aivar75
Simon.
thats why i asked does he uses split dns or single dns.
Roy DDDE
sembee,
Maybe there is some confusion, i do not have a casarray setup externallly. The internal dns name of the casarray is cascarray.company.com, and this does work ok internally.
The external dns name is something like webmail.company.com, this is pointed to my external ip, which is nat'd to the internal ip of casarray.company.com(192.168.1.10).
if i go to https://webmail.company.com/owa everything works 100%.
basically it looks like the redirection of going to https://webmail.company.com to https://webmail.company.com/owa is not working correctly.
also the redirection of going from http to https is not working either. our users should be able to go to http://webmail.company.com or https://webmail.company.com and it should redirect it to the https://webmail.company.com/owa
Roy DDDE
ya those are the instructions i followed originally. (brian desmond), and the redirection works internally, but when coming from the outside it doesnt work.
Aivar75
whats your external url has been set? as it has to resolv internally also. i assume you have there atm casarray.domain.com and should be your externalurl instead, and then make dns record to point external url to your casarray ip. and it should resolve your problems.
Sembee [MVP]
sembee,
In your original question you said that it was casarray.domain.com that was being used, now you are saying webmail. The confusion is caused by you. Which are you using? If the casarray host is not resolving outside, but you are using something else outside, then the use of the CAS array isn't really relevant, other than they are sharing the NLB configuration - if appropriate.
Personally I would undo whatever you did for the redirection, and confirm things work correctly internally and externally without it.
Simon.
Roy DDDE
external url: webmail.compnay.com
internal dns name: casarray.company.com (this is setup this way so that when users configure outlook they just point it to casarray).
my only issue now is as i stated above.
" basically it looks like the redirection of going to https or http://webmail.company.com and having it redirect to https://webmail.company.com/owa is not working correctly."
N Problems accessing network files via OWA Using Outlook 5
R New users creating get page cannot be displayed when accessing OWA Exchange Server Administration 16
RBLampert Accessing Outlook accounts from multiple computers Using Outlook 8
E Accessing shared outlook folder doesn't work since switch to new outlook/excel Outlook VBA and Custom Forms 11
J Accessing calendar items for Resource Mailboxes Outlook VBA and Custom Forms 2
J Accessing Hotmail accounts with Outlook 2016 Using Outlook 3
n2b Accessing Plain Text Draft Without Outlook Using Outlook 3
G Issues with accessing Outlook Contact Picture with VBA Outlook VBA and Custom Forms 4
M Accessing ExpiryTime property Outlook VBA and Custom Forms 1
C Problem accessing events for folder "username" Server Threw Exception Calendar Printing Assistant 1
P accessing custom task pane with Outlook ActiveInspector Using Outlook 1
mikecox Accessing Outlook on my Win7 desktop from Win8 laptop Using Outlook 1
A "Unable to display the folder" error when accessing Group mailbox Using Outlook 0
Commodore Accessing mail from multiple devices Using Outlook 1
S Programmatically accessing Outlook Calendar data Using Outlook 1
E Accessing User Defined Fields in BCM Database part 2 BCM (Business Contact Manager) 0
E [SOLVED] Accessing User Defined Fields in BCM Database part 1 BCM (Business Contact Manager) 9
K trying to sync my samsung galaxy to my outlook 2010 calender. it says execution privilege prevents me from accessing outlook Using Outlook 1
P time delay between accessing Outlook file folders, up 20+ second delay Using Outlook 1
S Accessing source information Using Outlook 1
J After Window update of 12/15/2010, outlook 2007 gives error (0x800CCC18) when accessing gmail using Using Outlook 6
S Outlook 2010 freezes and not responding when accessing, moving or deleting files Using Outlook 2
M Mails get deleted accessing a user mailbox with a different user Using Outlook 2
N Shared Calendar in Public folder hangs when accessing from Outlook 2010 Exchange Server Administration 2
X Accessing a shared email folder - How? Exchange Server Administration 1
H Accessing a backup Using Outlook 3
J Problems accessing console of Exchange 2010 on Windows Server 2008 R2 Please help me Exchange Server Administration 4
S Accessing emails in a closed account Using Outlook 1
E Users get login prompt in Outlook 2007 when accessing Exchange Server 2007 Using Outlook 2
H accessing shared calendar in outlook 2007 Using Outlook 3
A BCM-Problem Accessing Database Using Outlook 1
K Outlook 2010 now freezes while accessing Gmail Using Outlook 3
S Accessing items in incoming emails. Using Outlook 1
N Outlook 7 crashing when accessing Tasks Using Outlook 2
D 403 Error in IIS when accessing a non-SSL page Using Outlook 2
L Not receiving all incoming mail when 2 computers are accessing 1 email address Using Outlook 1
O Accessing OST file which was created through Windows Outlook Connector Using Outlook 2
J Restriction on accessing hyperlinks contained in email. Using Outlook 2
C Accessing web addresses included in emails Using Outlook 1
J Accessing email from remote device. Using Outlook 2
T Outlook closes unexpectedly upon accessing another user's calendar Using Outlook 1
S Accessing Calender information post migration from Exchange 2003 to Exchange 2020 using Outlook2003 client. Exchange Server Administration 4
A Accessing shared calendar that is NOT DEFAULT calendar. Using Outlook 6
L reported error (0x80004005) : 'There is an error synchonizing your mail account. Please verify your account is configured correctly by first accessing Using Outlook 2
T Accessing Exchange Server 2010 using Mac Mail 4.3 Using Outlook 3
R Accessing folder 'Other Contacts' Outlook VBA and Custom Forms 1
E Accessing a Form Region from an Inspector Outlook VBA and Custom Forms 3
