how to get email editor to use normal.dot template, ie same as what word is using
rock hammer
It appears that all the keyboard shortcuts I added to word does not automatically flow thru to outlook email editor. Is there a way to make it happen? Is there a way to get the email editor to use the same template normal.dot as in word?
Brian Tillman
Copy Normal.dotm to NormalEmail.dotm and see if that helps. Those files are in %AppData%\Microsoft\Templates.
Dilshad VBA editor opens when sending an email Using Outlook 2
S Email editor, Outlook 2003 Using Outlook 4
A Can I turn off Word as the email editor in Outlook 2010? Using Outlook 2
H email editor context menu 2007. Outlook VBA and Custom Forms 1
W September 2020 - No Default Email Client message after Office Update Using Outlook 0
glnz O365 - How to send from acct 2 but showing email name from acct 1 as From - alias? Using Outlook 1
L Email with correct To address but displaying name of a related person Using Outlook 0
A Two Inboxes, Same Email? Using Outlook 3
J To delete the draft email Using Outlook 2
D Sending email from Office 365 alias in Outlook Using Outlook 3
S Macro or plug-in to see if specific person was included in this email Outlook VBA and Custom Forms 3
L Outlook saved email templates Using Outlook 1
T The non-email functions Using Outlook 8
P Outlook 2013 Word Share doc as Email Attachment now brings up Eudora. Using Outlook 1
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
J Outlook Reply > From > Other Email Address... > Address Not Showing in Sent Items... From Email Outlook VBA and Custom Forms 0
HarvMan Hotmail - Sending email is undeliverable Using Outlook 4
