best rule/macro to send emails from many people/orgs to same folder
L
lemon scented
I would like to set up a rule so that all emails that are informational only go to the same folder. The list of senders that should be included in this rule will change daily as new emails are received.
I tried doing this in with distribution list but received a message that this can't be done with a private distribution list but that the names within that distribution list can be individually listed.
So, now when I want to add addresses to this rule, I need to save each email address and either add them individually to the rule list (which is cumbersome) or save the address, add it to the distribution list, delete all the addresses in the rule list, and add the updated distribution list, which will then be saved by individual name (this is also cumbersome).
There must be an easier way to do something that is such a common task without requiring so many steps.
By the way, the reason for continuing to work with the distribution list is that the DL enables us to see who is in the list without having to scroll through all of the individual names in the rule list (why doesn't Outlook enable us to see those names without scrolling through a long line?).
Any suggestions for rules and/or macros would be deeply appreciated.
Roady [MVP]
What is the origin of these messages?
If these are for instance for newsletters, then you can opt to create an alias for your mailbox and subscribe to the newsletters with that address. Then you only need to a single rule;
if message is sent to <your newsletter address> move the message to the Newsletters folder.
L
lemon scented
The list will be constantly changing as I get on more and more people's lists. Yes, I could write to many of them and request that my address be changed but that is a lot of effort. Isn't there an easy way to designate that I would like future incoming messages from this sender to go to this box?
Roady [MVP]
Yes, but as you already noticed yourself; that will require you to update the rule each time you subscribe to a new list. Using an alias would be a "future proof" solution. You can of course simply leave the rule as is for your already subscribed addresses and start using an alias for your new lists.
Rupert Dragwater What is the best way to back up pst Using Outlook 4
Diane Poremsky The Best Outlook Store Add-ins Contest New Slipstick.com Articles 0
X Best utility for repairing PST files? Using Outlook 3
D a suggestion ...sent with the best intentions Using Outlook 1
M How best to track OUTGOING referrals? BCM (Business Contact Manager) 2
M best duplicate contact remover? Using Outlook 6
G what is the best way to organize outlook contacts Using Outlook 1
D What would be the best strategy? Using Outlook 3
J Best way to move form old to new, larger pst? Using Outlook 2
M Best way to move outlook? Using Outlook 1
R Best way to share outlook calendar with 10 laptops Using Outlook 9
Horsepower Email best practice Using Outlook 3
N Outlook 2010, Categories, best way to filter contacts? Using Outlook 5
F Best Non MS Exchange 2010 book for beginners? Exchange Server Administration 7
S CAS/MBX reboot best practices. Exchange Server Administration 7
I Best Practice for Large Messages NDRs? Exchange Server Administration 4
R Any "Best Practices" for a test/developer Exchange 2010 server? Exchange Server Administration 2
C Best way to effectively back up Outlook Calendar (and save Categories) and Email as well???? Using Outlook 6
R Best practices for creating "Equipment" mailbox resources? Using Outlook 1
D Exchange Best Practice for DEV/TEST/PROD Exchange Server Administration 2
M Exchange 2010: What to monitor - best practices Exchange Server Administration 4
K Best case scenerio to reduce disk space usage Exchange Server Administration 5
B Best way to get a pick-list on a form? Outlook VBA and Custom Forms 1
M Best way to distribute VBA project Outlook VBA and Custom Forms 4
T Is Explorer.FolderSwitch the best event for hiding commandbarbutton? Outlook VBA and Custom Forms 5
