Outlook 2010, Categories, best way to filter contacts?
N
nkee1229
I have an Outlook Contacts database with about 3,000 names. Of those, I consider about 600 of them to be my " core" contact. Is there tool in Outlook or any application/add-in that would allow me to categorize groups of contacts based on frequency of contact so that I don't have to go through them one-by-one, manually?
I thought about exporting my entire .pst email folder and opening that up in Excel, then doing a sort by date. Then, exporting my contacts as .csv files and doing a vlookup or linking those two tables somehow??? I'm guessing Access would be a better program to use b/c I could link the fields and do a simple query using the date of the email, but I'm not that familiar with Access... I'd be willing to learn, though, if I have a clearcut plan of action. At this point, I wouldn't know what to do with the data even after it's been sorted in Access (ie. how to get that back into Outlook in an organized manner).
Help!
Russ Valentine
What do you mean by the " frequency of contact?" What property were you proposing to use to indentify " core contacts?"
Exporting and importing through another file type just to rearrange or organize Contacts is genrally a bad idea. Outlook has plenty of ways to label or organize contacts once you can identify them without your losing the data you lose by exporting and importing.
Russ Valentine
N
nkee1229
Russ,
Thank you for taking the time to respond to my thread and dig deeper. I appreciate it. As for your question, I am trying to help my boss identify & categorize which contacts he has been corresponding with most often and which contacts have fallen off " the grid" . I was hoping there was some sort of a sneaky way to link his contacts to his emails and somehow " rate" his clientele based upon how often they actually correspond. Overly-ambitious, huh?...
Natalie
Russ Valentine
The only thing I can think of is to look at the Activities page in the Contact record, which will create a dynamic list of all email correspondence with the Contact in question. It is largely broken in Outlook 2010 but should still work for emails.Russ Valentine
N
nkee1229
Russ,
I'm not familiar with the Activities page. What do you mean by " largely broken" ? Is this activities feature available for Outlook 2003?
Russ Valentine
In outlook 2007 and 2010, click on " Activities" in the Ribbon. In Outlook 2003 you'll find it as a separate Tab.Russ Valentine
V Outlook 2010 – Send email based on categories Using Outlook 2
S Missing Color Categories Outlook 2007/2010 Using Outlook 2
B synchronizing categories of contacts between outlook 2010 and business contact manager Using Outlook 1
A Outlook 2010 categories disappear Using Outlook 2
I Contact categories problem when upgrading from 2007 to 2010 Outlook Using Outlook 1
T In Outlook 2003 and 2007 you had Categories for contacts. Where is it in Outlook 2010? Using Outlook 3
