How to copy and paste in Outlook 2010 ?
JohnInSing
I want to copy an item from 1 day and paste it to another (fairly basic request)
I select the item I wantto copy, and press Copy on the Ribbon
I move to the new date, select the day, and press Paste
Hey Presto - Outlook puts a copy of the item IN THE ORIGINAL day, not the new day
It gets worse - whereas old Oultook would normally only put a single item, even of a recurring series, I now find that Outlook has put a whole series of items, exactly where I don't want them
Roady [MVP]
That's because you are copying a recurring item, the behavior you are expecting only applies to single items. This is indeed a design change from Outlook 2007 as people were actually expecting to copy the recurrence pattern as well.
To create a single item copy of an appointment with a recurrence pattern, click the appointment with your right mouse button and hold down the mouse button while you drag and drop it on its new day/time. Now you can choose to Move or Copy the item. Choosing " Move" will create a one-off for the current series and choosing " Copy" will create a single item copy unrelated to the original series.
Robert Sparnaaij
JohnInSing
I find that really wierd - different copy/paste behavior depending on single or recurring ietm ? Who's bright idea was that ? So the people who were expecting to copy the whole recurrance would actually prefer that it does NOTHING (or actually worse than nothing) rather than at least move the single item ????
I guess I'll just have to get used to it, but seems like just one more downgrade as I move to Office 2010
A Outlook: copy & paste Outlook VBA and Custom Forms 9
R Copy/paste mailing address Outlook 2013 Using Outlook 6
S I'm not able to copy and paste on outlook. Using Outlook 1
M Outlook 2007 Copy-Paste problems Using Outlook 6
F I cannot highlight text in Microsoft Outlook 2010 e-mails, and copy/paste to the body of another e-m Using Outlook 3
S Copy/Paste from Office Word 2003 to Outlook 2003 Using Outlook 3
O How do I copy and paste calendar dates in 2010 outlook? Using Outlook 1
D Open attached CSV, copy newdata and paste it to database CSV Outlook VBA and Custom Forms 2
O Copy email content and paste into new Word Document using a different font Using Outlook 1
L "sometimes" cant send mail, we have to copy and paste the message and resend? Using Outlook 2
J cannot copy and paste while in list view in-cell editing Using Outlook 1
J OWA copy/paste and drag/drop Question Exchange Server Administration 2
D Problem with Microsoft Office 2010 Clipboard (Copy and Paste) Using Outlook 1
I Office 2003 Crashes when trying to Copy, Paste, or Save with Windows 7 Professional Using Outlook 4
R how to copy a list of email contacts and paste them only as names (not names + email address) Using Outlook 12
K Copy Entire Email Content - Paste into new Task Outlook VBA and Custom Forms 2
K How to copy Contact Item to Clipboard and Paste as "VCF Link? Outlook VBA and Custom Forms 4
S Using copy paste to grab email addresses from the TO: address fiel Using Outlook 14
