How to print multiple calendars using calendar printing assistant
H
hblimited
Calendar Printing Assistant has been installed and the client restarted. How do I access the program to print multiple calendars?
Sachin Shetty
Try these steps and check.
1. Load both Outlook and the Calendar Printing assistant, select a multi-calendar template from the view templates panel on the right-hand side of the interface.
2. You will notice that the View Templates title is actually a select list. Toggle this to Calendars and Tasks:
3. Click on the calendars you want to display. They will appear in the Calendars and Tasks bar on the left-hand side of the interface.
4. Check the calendars you want to print, they appear in the template.
Diane Poremsky Combine and Print Multiple Outlook Calendars New Slipstick.com Articles 0
P Print multiple pocket calendars on one page Using Outlook 5
R Print full text of multiple e-mails in table format Using Outlook 1
A how to print multiple emails from Outlook 2007 Using Outlook 13
Q How to print multiple (2) weeks on one page? Calendar Printing Assistant 3
A Day view - print appointment details Calendar Printing Assistant 1
I print calendar without subject and details Using Outlook 1
oliv- property "is printed" or catching print events Outlook VBA and Custom Forms 2
Diane Poremsky Print a list of your Outlook folders New Slipstick.com Articles 0
B Print list of previously sent recipients Using Outlook 1
R Print email message and attachment in order Outlook VBA and Custom Forms 2
A Print first page of a new email Outlook VBA and Custom Forms 7
Diane Poremsky Print Monthly or Work Week Calendars New Slipstick.com Articles 0
Diane Poremsky No drop down calendars in Outlook 2010 Print Options New Slipstick.com Articles 0
S Macro to print & move selected emails? Using Outlook 3
J Auto print PDF attachments as they arrive with certain words in subject Outlook VBA and Custom Forms 3
G Calendar monthly view - Print just 3 weeks Calendar Printing Assistant 5
R Can't modify Outlook view font with IE anymore (even though IE still affects print font) Using Outlook 5
M Print Attachments from another mailbox (not default) Outlook VBA and Custom Forms 2
L Outlook 2010 Quick Print Attachment, nothing happend Using Outlook 0
C automatically print attachments Using Outlook 4
J Automatically Print PDF When They Are Received Using Outlook 4
M button to send and print emails Using Outlook 26
S How to print ONLY first line of appointments in month view? Using Outlook 1
M print free/busy schedule of an user Using Outlook 2
O For Outlook 2007 - VBA to print attachments Using Outlook 1
W Cannot print Outlook 2007 emails Using Outlook 2
R problem with incomming e-mail I am unable to print full e-mail letter Using Outlook 1
M Custom print contacts Using Outlook 2
E Can't print from Outlook on wifi network Using Outlook 0
E can't print some retail discount coupons Using Outlook 7
J calendar print setup in outlook 2010 Calendar Printing Assistant 1
J Outlook 2010 using Quick Print to print attachments Using Outlook 1
D Use Outlook 2003 embedded imaged cannot print from the mail preview list Using Outlook 4
J Print next 7 days view of calendar (2010) Using Outlook 3
C Print all emails in a single folder with sent items Using Outlook 2
I Outlook 2010 Print Created Date on Drafts Using Outlook 3
P Mail Merge vs Direct Mail Print BCM (Business Contact Manager) 4
A Print / View / Contacts Using Outlook 1
