Outlook 2003 won't connect to Hotmail.
jackie.burns
This is the error message: Task 'Hotmail:Folder:Inbox Synchronizing Headers' reported error (0x800CCC33): " Access to the account was denied. Verify that your username and password are correct. The server responded 'Forbidden'.'
I've used Connector before--and loved it--but I had to replace my hard drive this summer, and the problems started then. I can still use Hotmail online--with the same account & password, but I prefer Outlook because of fonts, & easier junk mail folders. I've re -downloaded Connector 3 times--once using Explorer, twice using Mozilla, and it makes no difference. When I go to send/receive, I get this error message.
jackie.burns
*OOOPS! This might be a double-post. But I didn't want to take the chance and close the tab.*
Ben M. Schorr [MVP]
What anti-virus software are you using? You might try disabling it, temporarily as a test, and see if the problem persists.
jackie.burns
STILL not resolved. I even closed Outlook and re-started my computer. Re-entered my hotmail account info, and specified the info about my internet connection and got the exact same error message when I hit Send/Receive: Task 'Hotmail:Folder:Inbox Synchronizing Headers' reported error (0x800CCC33): " Access to the account was denied. Verify that your username and password are correct. The server responded 'Forbidden'.' It was even the same error code--but that's probably just a generic code. So, am I S-O-L(sorry, out of luck) as far as Outlook Connector? I use Norton 360 as anti-virus protection now, as opposed to McAfee before when it worked--is that the issue?
Relative Ray
How is the Hotmail a/c configured in Outlook?
Install OL connector and then try to configure email a/c
jackie.burns
as the default email. I even un-installed my Norton anti-virus and tried that....I checked the tasks of the error message, and it said that sending was ok, just the sychronizing headers...
Ben M. Schorr [MVP]
This might sound like a silly question but, just to be clear...you say you downloaded the Hotmail Connector....but did you INSTALL the Hotmail connector?
I Outlook 2003 won't send emails through one router, but will through another Using Outlook 1
B Outlook 2003 PST File Won't Compact Using Outlook 1
D Outlook 2003 won't send emails to gmail or yahoo addresses Using Outlook 2
W Outlook 2010 won't send mail from 1 account, but i can send it in outlook 2003 Using Outlook 1
S Outlook 2003 Won't use Word as the E-mail Editor Using Outlook 1
T Outlook 2003 with multiple explorers won't shutdown Outlook VBA and Custom Forms 2
I Outlook 2003 shows html code when To: field is empty Using Outlook 5
O Duplicate folders in Outlook 2003 Using Outlook 3
O Moving OUtlook 2003 from bad XP to Win 7 Pro 64 -- URGENT! Using Outlook 8
R Menus in a new\old email not there in Outlook 2003 Using Outlook 2
