My Outlook 2010 Beta Trial ended, I need help getting email and contacts.
F
Fuggie2
My Outlook 2010 Beta Trial expired on me and I need to recover some saved emails and contacts from the program. When I start the program it goes to a box that says my trial has ended and will not let me do anything. If you click anywhere in the popup it closes the program. Please tell me there is a way to recover this info.
Ben M. Schorr [MVP]
Well, you could buy the program.
Or you could download and install the released trial version - that's fully functional for 60 days.
Did you not see the many notices that warned that the beta was going to expire on October 31st?
V
Vinay - G
Outlook data is stored in the form of PST file if your account type is POP3. You need to uninstall Outlook 2010 beta and install Outlook 2010 full version and it will automatically pull all your Outlook data.
You can locate the PST file under the following location.
Navigated to C:\Documents and Settings\ Username\Local settings\Application Data\Microsoft\Outlook
You can copy the PST file and save it in a different location or an external hard drive.
Traace
Sorry, accidentally voted your answer as helpful - I'm new here, just thought that I could rate helpfulness from 1-10, turns out that's not the case.
I'm another one who didn't get the 'many notices' saying that the beta was expiring - they all went to my spammy hotmail address that I don't use for correspondence, only for logging in when Microsoft forces me to not use my gmail address.
C
corlando
I installed the trial version and it didn't pull the other emails over....
R Upgrading to licensed copy from 2010 beta - Outlook won't work Using Outlook 1
E After 2010 Office Beta expired, my 2007 Outlook version stopped working properly. Can not access correct profile and synchronization with Blackberry p Using Outlook 1
J outlook 2010 download erase the details from my beta version? Using Outlook 2
E My Microsoft Office 2010 Beta version has expired. How do I backup my Outlook contacts and email bef Using Outlook 1
G Outlook 2010 Beta has expired Using Outlook 1
J outlook will not open, uploaded new 2010 to replace beta version and everything but outlook works. ____ Using Outlook 4
F outlook 2010 beta email export Using Outlook 7
S Outlook 2010 Crashes consistently on second reply to an email ... (Release, and not Beta version) Using Outlook 1
S Outlook 2010 Beta crashes quite often Using Outlook 2
K Connecting Outlook Pro 2010 (beta) to Windstream mail Using Outlook 6
G Outlook 2010 Beta doesn't appear in the Default Programs under Control Pane Using Outlook 2
K Microsoft Outlook and Office 2010 beta: not recognised? Using Outlook 2
M Outlook 2010 Beta: Error When Moving Email from Inbox to Personal Folders Using Outlook 0
S Import Messages to Outlook 2007 2010 and 2011 Beta From Entourage 2008 Using Outlook 7
R Outlook 2010 Social Connector NOT working (not Beta, final version) Using Outlook 6
J Outlook 2010 Beta spell check not working Using Outlook 8
O Problem importing a csv contact file into outlook 2010 beta Using Outlook 15
M Blackberry sync with Office 2010 Beta Outlook Using Outlook 8
D Outlook 2010 Beta Calendar Appointment Reminder Sound is WAV only. Using Outlook 5
J Outlook 2010 beta closes and restarts when moving between mail messages Using Outlook 22
R Office Outlook 2010 Beta #550 error: Using Outlook 2
Diane Poremsky Outlook 2010 beta and the Connector Using Outlook.com accounts in Outlook 1
T Why does outlook 2010 convert only some forum notifications to plain text? Using Outlook 2
