Outlook 2010 will not archive auto or manual
C
CPGill
I can"t seem to get Outlook to archive at all. Automatically or manually. I believe I have everything set up right. I get the prompt OK to run AutoArchive and nothing happens. No message and nothing is moved. If I try to manually run archive same thing. I am using Gmail and was using IMAP for a while. One of the reasons I am switching back to POP is because I discovered the archive feature will not work with IMAP. My e-mail was getting to big and slow. I now have everything back in my POP pst file but I can"t get the items to archive. I am wondering if switching to IMAP and back caused something to get out of synch? I have been an Outlook user for many years and archive has always worked in the past. Any suggestions
K Change the default Archive location via GPO in Outlook 2010 Using Outlook 3
S Outlook 2010: How do you enable Contacts' Activities to search archive folders Using Outlook 6
P Exchange 2010 - Outlook 2010 : Search in Online Archive not working Exchange Server Administration 3
K online archive missing Outlook 2010 Using Outlook 11
J Easy archiving certain message in online archive? Outlook 2010 and exchange 2010 sp1 Exchange Server Administration 5
L Cannot see online archive with Outlook 2010 RTM Exchange Server Administration 9
