Outlook 2007 crashes on start up, but not in safe mode
F
FredAnz
This issue has just started. At first I was getting blue screens with " bad_pool_header" when opening emails in Outlook or inputting information into Firefox (like in a Google search), but managed to fix those issues with a system restore. This issue with Outlook is the last thing I am trying to fix.
It appears the faulting module is the mso.dll in Outlook. I have tried scanpst.exe, creating a new profile, running office diagnostics/repair, and disabling all of the Com Addins except the email indexer, without any luck. Outlook does work ok in Safe mode.
Would appreciate any help. Other programmes seem to be working as normal. There are no new hardware or software items.
The event viewer information is as follows:
Fred
Log Name: Application
Source: Application Error
Date: 13/11/2010 8:11:30 p.m.
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: Laptop
Description:
Faulting application name: OUTLOOK.EXE, version: 12.0.6539.5000, time stamp: 0x4c12486d
Faulting module name: mso.dll, version: 12.0.6545.5004, time stamp: 0x4c9344d2
Exception code: 0xc0000005
Fault offset: 0x00053a22
Faulting process id: 0x14c0
Faulting application start time: 0x01cb8301fd961780
Faulting application path: C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE
Faulting module path: C:\Program Files\Common Files\Microsoft Shared\office12\mso.dll
Report Id: 3cb397ab-eef5-11df-b548-1c4bd6017292
Event Xml:
<Event xmlns=" http://schemas.microsoft.com/win/2004/08/events/event" >
<System>
<Provider Name=" Application Error" />
<EventID Qualifiers=" 0" >1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime=" 2010-11-13T07:11:30.000000000Z" />
<EventRecordID>36115</EventRecordID>
<Channel>Application</Channel>
<Computer>Laptop</Computer>
<Security />
</System>
<EventData>
<Data>OUTLOOK.EXE</Data>
<Data>12.0.6539.5000</Data>
<Data>4c12486d</Data>
<Data>mso.dll</Data>
<Data>12.0.6545.5004</Data>
<Data>4c9344d2</Data>
<Data>c0000005</Data>
<Data>00053a22</Data>
<Data>14c0</Data>
<Data>01cb8301fd961780</Data>
<Data>C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE</Data>
<Data>C:\Program Files\Common Files\Microsoft Shared\office12\mso.dll</Data>
<Data>3cb397ab-eef5-11df-b548-1c4bd6017292</Data>
</EventData>
</Event>
Joe's answer
Ensure Outlook is not running in compatibility mode:
Click on Start > Computer > C-Drive (C :) > Program Files or Program Files (X86) > Microsoft Office > Office12
Locate the Outlook icon, then do a right-click on it and select "Properties"
Select the "Compatibility" tab then uncheck the "Run this program in Compatible mode for" option
Click on Apply and then select OK
D Outlook 2007 crashes opening email with image links Using Outlook 4
M My outlook 2007 will not open, it just gets stuck and my computer crashes. Using Outlook 1
S Re: Outlook 2010 crashes when upgraded from Office 2007 Using Outlook 1
T Outlook 2010 crashes when upgraded from Office 2007 Using Outlook 1
P Outlook 2007 Crashes Opening Scheduling Assistant On Some Client PC's Using Outlook 2
L MSOffice 2007 Outlook functions normal, but crashes on specific email's when a reading pane is open. Using Outlook 7
T Outlook 2007 crashes moving emails from inbox Using Outlook 1
O Re: OUTLOOK 2007 Crashes on startup Using Outlook 6
Y Outlook 2007 crashes while inserting network shared path hyperlink into mail body Using Outlook 8
F Outlook 2007, crashes when you open sent items Using Outlook 3
M Outlook 2007 crashes with BCM BCM (Business Contact Manager) 1
S Macro for other actions - Outlook 2007 Outlook VBA and Custom Forms 18
Diane Poremsky Manually create a POP3 account in Outlook 2007 New Slipstick.com Articles 0
