Installing Office 2010 Outlook 64 bit over 32 bit
L
LoneOak
I installed Office 2010 32 bit on my Windows 7 64 bit computer because I didn't realize that the install program defaults to 32 bit even though the OS was 64 bit. After a couple of months, I discovered that bit of information. So now I want to reinstall Office 2010 as the 64 bit version but must first uninstall the 32 bit version. For most Office programs this is a no brainer since all the data files are independent of the installation and I have made no customizations. Not so for Outlook though. I do not want to loose my account settings, nicknames, custom views and quicksets, rules, etc.. I know that the data files (pst) are in My Documents. Where do I find all of the rest of the "set up" files for Outlook 2010? Can I just back those up and reinstall them after uninstalling and reinstalling Office 2010?
You won't lose anything when you uninstall 32-bit. Outlook will pick up the old profile and settings. (Rules and autocomplete cache are stored in the mailbox or pst.)
Note that if you use addins or sync with a smartphone, you'll want to keep the 32bit version as many addins won't work with 64bit outlook.
L
LoneOak
Thanks, loads. I took your word for it and did the 32 bit uninstall and 64 bit install. Everything was carried over including Quick steps, nicknames, and view setting.
matutolas
I don"t think is a matter of losing anything or not. the question we need to ask is why Microsoft doesn"t support their own products? i still can't believe we need to uninstall office 2010 64 bit to be able to sync with my windows mobile 6.5. This is really ridiculous, Microsoft should fix this issue and not asking people to downgrade from 64 bit to 32 bit.
J Outlook won't open after installing Office 2010 Using Outlook 1
S RE: BCM won't open after installing Office 2010 Beta BCM (Business Contact Manager) 2
M ctrl-c/v/x suddenly not working since installing office 2013/365 Using Outlook 1
B Trouble installing office because of outlook and BCM? Using Outlook 1
Mark Foley Color Categories on IMAP mail lost when installing new Windows 7 workstation Using Outlook 12
R Installing BCM BCM (Business Contact Manager) 0
C Error installing BCM: requires outlook BCM (Business Contact Manager) 25
C Outlook 2010, Need to restrict domain users from installing any sort of a addin in outlook Using Outlook 2
R Missing Backup command in File menu after installing pfback.exe Using Outlook 2
V Installing Apps from MS Online Store Using Outlook 5
S Installing Exchange 2007 on Outlook 2007 with a previous POP3 account Using Outlook 1
I Links not working after un-installing Google Chrome Using Outlook 2
S Installing Outlook 2007 - but using Windows Live Mail as 'the Master' for mails Using Outlook 3
G Installing an email cert into Exchange OWA Exchange Server Administration 6
S 6 to 8 second delay in folders opening since installing a number of updates yesterday. Using Outlook 1
M Unable to receive after installing updates Using Outlook 1
M After installing Exchange 2010, how to get things to work????? Exchange Server Administration 1
H Outlook 2007 slow folder content display after installing kb2412171 Using Outlook 33
R Can not import dbx files from outlook express into outlook 2003 after installing windows 7 64 bit Using Outlook 1
W installing exchange 2010 with multiple forest (Cross-forest) Exchange Server Administration 2
S OWA in Exchange 20120 not working after installing a new certificate and applying SP1 Exchange Server Administration 1
C Installing Outlook 2003 on a new Windows 7 Desktop and transferring data via Easy Transfer Using Outlook 3
D Installing SP1 for Exchange 2010 Exchange Server Administration 2
Y error when installing mailbox role Exchange Server Administration 4
C Get "The installation of this package failed" errmsg when Installing Facebook Connector. Using Outlook 2
J Installing MS Hotmail on OUTLOOK list Using Outlook 2
H Exchange 2007 - After Installing Forefront on My Exchange , OWA encountered an error Using Outlook 2
J Roll Back Options for installing SP1 on a DAG Exchange Server Administration 5
S Installing New Exchange 2010 Exchange Server Administration 4
S Installing Exch2010 Exchange Server Administration 3
I I get a COM class error when i open Outlook after un-installing Trend Micro client Using Outlook 4
D Enabling UM on a user after installing SP1 Exchange Server Administration 2
C Installing Exchange 2010 SP1 in a Sub domain... Exchange Server Administration 5
C Now the problem I see is that I get an error when installing the Exchange 2010 SP 1. I attach a scre Exchange Server Administration 10
C Installing Outlook 2007 into new computer with Outlook 2010 trial software Using Outlook 2
G Problem with Outlook 2010 after installing update to Word Perfect X5 Using Outlook 4
S Removal of Interim Update packages before installing any Exchange Server 2010 service pack Exchange Server Administration 1
A Error Installing Exchange 2010 SP1 on Exchange 2010 Exchange Server Administration 5
T Prerequisites softwares for installing exchange 2010 edge transport server on windows 2008 R2 Exchange Server Administration 1
C Installing a new Exchange Server with 2010 Exchange Server Administration 2
C Mouse freezing in Outlook 2003 after installing Adobe Acrobat Professional 2009 Using Outlook 1
E Gmail IMAP not working since installing junk mail filter update Using Outlook 1
D Problem with installing Exchange 2010, AD problems? Exchange Server Administration 16
J Installing Entourage 2008 Web Services Edition Using Outlook 1
S Re-installing the server and upgrade to 2010 Exchange Server Administration 6
O Error while installing the umLanguagepack-DE Exchange Server Administration 2
