Outlook's Rules Wizard; No 'Forward using a specific template' Rule
1borland
I'm wanting to set up a rule in Outlook for sending e-mail alert messages when incoming message content contains specific words. Using the Rules Wizard, I don't see a rule that would allow me to do this.
What I need is a rule like this: 'Forward using a specific template'. There exists a rule 'Reply using a specific template', but that's not useful, as I'm not wanting to send the alert to the sender. I need to use a template because I don't want to forward any content from the sender.
Is there another way to approach this? Thanks
1
1borland
I was thinking as a work around, I could...
Rule 1: using rule actions: 'With specific words in message subject or body' and 'Forward the message', to my InBox.
Rule 2: using rule actions: 'With specific words in message subject or body'and'from People or Public Group' and 'Reply using a specific template', again to my Inbox, then
Rule 3: using rule actions:'With specific words in message subject or body' and 'Forward to People or Specific Group'.
That should work, but a bit messy.
Another problem with this work around is that the Alert messages would be delayed a minimum of 2 minute, as these rules processing would be limited by 'Schedule an automatic Send/Recieve every [ xx] minutes' setting in Outlook/Options/Advanced menu.
1
1borland
Well, I did some experimenting with this 3 rule work around. Rule 1 works fine. But Outlook fails to process rule 2 (error).
Apparently Outlook can't Reply... to the sender.... using a specific template. That software bug sucks.
Sachin Shetty
Remove all the rules and recreate it and check if it helps.
1
1borland
Thanks for the help Sachin. I tried that, but still get the same error message..... " Cannot reply to message" .
Don't see how it could be, but do you think the Hotmail connector for Outlook is causing this error?
Is it possible to write a macro using VBA that adds a rule action or runs a rule action custom script? I know you can record macros of just about anything that you can manually do, using the keyboard and mouse, but I don't think you can manually run most rule actions.
D Rules Wizard Outlook 2010 limitations Using Outlook 1
M Outlook 2010 Rules Wizard Enter Multiple Items at once? Using Outlook 0
Wayne Outlook locks up when opening "Manage Rules & Alerts" Using Outlook 7
D Outlook Rules Using Outlook 1
Gunny NFOhiway Outlook PST file and Rules Using Outlook 1
M Outlook 2016 Rules Not Working Automatically Using Outlook 5
A outlook 2007 how to chcek all rules ? Outlook VBA and Custom Forms 2
J Outlook Rules not show Master Category List Using Outlook.com accounts in Outlook 4
R Outlook rules Using Outlook 3
M Outlook 2007 IMAP Account Rules Issues Using Outlook 3
D Outlook Rules - How to use a variable in the subject condition Outlook VBA and Custom Forms 9
A Setting RULES with more than one condition in MS OUTLOOK Using Outlook 6
J Outlook rules and alternatives Using Outlook 2
Rupert Dragwater How to delete old rules and create new in Outlook 2013 Using Outlook 12
H Using Outlook Rules to search for NewLines in message body Using Outlook 1
R Outlook - alternatives to Rules / Junk? Using Outlook 5
R Outlook 2013 - IMAP & Rules Broken Using Outlook 1
D Trying to repair Outlook rules Using Outlook 5
V Importing Rules in Outlook 2013 Using Outlook 2
T Adding text to forwarding rules in Outlook 2010 Using Outlook 1
T Adding tex to forwarding rules in Outlook 2010 Exchange Server Administration 1
D Outlook 2010 Rules: fwd meeting invitation results in winmail.dat not .ics Using Outlook 4
M Outlook 2010 IMAP rules occasionaly stop working Using Outlook 4
K Smartphones, Outlook and Rules Using Outlook 0
W Fwd Outlook incomming messages to usb port after Rules and alerts applied Using Outlook 0
P Outlook 2013 rules -- not working reliably -- moving messages to wrong boxes Using Outlook 0
J Outlook 2013 - Rules and Alerts for POP3/IMAP Accounts Using Outlook 1
S Outlook 2010: Message Rules come back next time I restart Outlook Using Outlook 0
D Unable to transfer rules from one Outlook computer to another Using Outlook 5
R Outlook 2013 Rules not working Using Outlook 1
S Outlook 2013 - All rules simply delete the email Using Outlook 1
M Rules in Outlook 2013 Exchange Server Administration 9
K Outlook Cached Mode - can't create rules to move email to another mailbox Using Outlook 2
J Outlook rules help Using Outlook 1
J Outlook - rules and Alerts Using Outlook 1
V Outlook 2010 non working rules Using Outlook 1
M Rules & Alerts not appearing in the File Tab (outlook 2010) Using Outlook 1
S Outlook 2010, need script for rules & Warnings Using Outlook 3
