Using Microsoft Exchange with Office 2007 conflicts with Office 2010 Home & Student Edition
K
kanps
I cannot setup my Microsoft Exchangeprofile in MS Office 2007, it keeps telling me I already have a messaging profile and Outlook shuts down. Do I have to uninstall Office 2010, setup Outlook, and then reinstall Office 2010?
Russ Valentine
Start at the beginning with clear delineation of the steps you used to create this problem. From your post it appears you are attempting to run 2 different versions of Outlook. Surely that isn't the case. No one would ever try that. It's never been possible.Russ Valentine
K
kanps
MS Office 2010 Home & Student only includes Word, Excel and Powerpoint, and does not include Outlook.It may include a free 30 day trial? Could this be the problem? The Outlook 2007 download/installation comes from my email provider/host as part of their Microsoft Exchange package.
H
Hal Hostetler - Print-Imaging [MVP]
" Exchange Server" is a messaging service that is added to a messaging profile. If you already have a profile, you should be able to add the Exchange Server service to it. 'Control Panel|Mail|E-mail Accounts', if the Exchange Server service is present, it needs to be configured, if it isn't, click the " New" button to add it.Hal
Did you buy office online and install the pro trial? If so, yes, it could be a problem. You need to uninstall the trial and reinstall or repair Outlook 2007.
Do you use an Exchange server mailbox? Did you have a profile setup in outlook previously?
W Outlook Anywhere, Connect to Microsoft Exchange using HTTP Using Outlook 6
S Importing a PST file into Office 2003-OPEN WITH using Microsoft 2007!! Using Outlook 1
C How come when I send e-mails using Microsoft Outlook and I am in my aol address, the e-mails I send go to my sent box in my Personal Folder rather tha Using Outlook 2
D Microsoft e-mail disappearing from outlook and web, but still visible on iPhone using outlook connector Using Outlook 5
S Using Microsoft Outlook (2003) contact list to print envelopes in Microsoft Word Using Outlook 5
T microsoft outlook 2007 won't start. Been using it fine for months. What's up Using Outlook 1
J Suddenly, I have 400 old Emails added to my inbox. I am using Aol with Microsoft Outlook 7. Using Outlook 1
