Creating personal folders on outlook 2010 and setting properties.
  • Thread starter Ageisjustanumber
  • Start date
Ageisjustanumber
On my outlook 2007, I have many personal folders where I put items from certain people. Those items may be pictures from my phone, e-mails, etc.. with no way to identify them under a certain catagory as 2010 trys to do with search folders, and I can find no way to create standard folders which are not search folders.
Also, the search folders copy everything as opposed to moving it, and it is still linked to the in box so that I have duplicates of everything and when I try to delete the inbox copy it deletes the one in the search folder as well.
Is there any way to change the properties on the search folders?
NOT HAPPY WITH 2010 OUTLOOK SO FAR.
thanks,
Andy
Andre Da Costa [MVP]
For Microsoft Outlook issues, you should post your question in Microsoft Outlook Answers Forum. This forum is for Windows 7 issues.
Outlook questions? -Answers Home PageTeching It Easy: With Windows |ActiveWin |Notebooks | Microsoft MVP
P
Palcouk
thanks,
Andy
Search folders are simply filtered views, they are not seperate folders, therefore you will see the behaviour you complain about.
R Creating a user defined function Outlook VBA and Custom Forms 3
O How to prevent CC from showing when creating a new mail? Using Outlook 1
N Creating a button or link to a form in the Organizational Forms Library Outlook VBA and Custom Forms 3
B Creating an email with the list of tasks Outlook VBA and Custom Forms 0
L Creating drafts when I thought I was sending Using Outlook 1
R Would creating a new profile cause Outlook to download all the old mails from the server? Using Outlook 1
A Creating Progress Bar or Status Bar Update Outlook VBA and Custom Forms 0
T Outlook creating a folder named: "Unwanted" Using Outlook 3
Liza Creating a rule in outlook to filter messages Using Outlook 0
S Creating Email - Selecting Pre-Defined Text Using Outlook 2
M Creating Outlook Appointments from Excel Cells Outlook VBA and Custom Forms 1
N Creating New Profile Using Outlook 0
M creating email from contact file = 3 emails in To field Using Outlook 3
P Recover / Extract Rules from standalone PST file creating RWZ file Using Outlook 2
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
I Creating meeting invite with disabled tentative button Outlook VBA and Custom Forms 5
E Creating email templates for organizational use Using Outlook 0
D Creating custom view with VBA Outlook VBA and Custom Forms 2
J Outlook creating unwanted rule on its own Using Outlook 1
R Creating a Room Mailbox with Exchange Online Outlook VBA and Custom Forms 0
A Creating a rule on “Deleted items” folder Using Outlook 1
CMG73 Creating templates with predefined subject and CC Using Outlook 1
G Creating Contact Sub Folders Using Outlook 2
Rupert Dragwater creating gmail account in Outlook 2013 Using Outlook 7
nathandavies Creating a Select Case for a directory of folders Outlook VBA and Custom Forms 1
2 creating custom stationery Using Outlook 2
A Help creating macro for conditional formatting settings Using Outlook 8
Fozzie Bear Creating Custom Meeting Form Outlook VBA and Custom Forms 6
U Creating a (This computer only) folder within an IMAP account directory Using Outlook 1
A Creating archive rule on the clients by script/ Outlook VBA and Custom Forms 3
J Creating a URL from a message body excerpt before forwarding Using Outlook 2
A Creating rule to create week folder and transfer mail using alert Using Outlook 3
J Creating an "isolated" shared calendar in Outlook Outlook VBA and Custom Forms 1
L Creating a Task from Email and Attaching Original Email Outlook VBA and Custom Forms 6
S Creating custom rule to move if "NAME" is in body but ignore the phrase "Hi NAME" in the search Using Outlook 2
witzker Outlook bug when creating a user defined contact form? Using Outlook 1
G Creating an Outlook Rule using Internet Header time Using Outlook 1
Wotme Creating a Outlook task in Excel Using Outlook 7
V Need to add some text in subject while creating new mails - NEED VB CODINGS Using Outlook 4
G Questions on creating Outlook forms Using Outlook 0
P Creating custom contact forms Using Outlook 2
K Outlook 2010 creating extremely large PST files for IMAP accounts Using Outlook 3
