Emails sent from Outlook 2010 are being received with some corruption of the body text
N
Neil T Holland
Hi; This is the 4th time I've posted this issue. Each time the response has been that it's being caused by the AV software. However this does not seem to be the cause because: 1. We use MSE and I've been assurd by the MSE team that MSE does not touch the incoming/outgoing email itself (only the attachments), and 2. We tried deactivating the AV software and the problem still occured. The MSE team had numerious other suggestions -- ex. deactivate Windows Defender -- which we tried but they did not help.
Description of the problem follows below. Please note that we are putting further installs on hold until we can get a fix, as this is a serious problem made even more so by the unpredicatability of it and the lack of direct feedback when an error takes place. Also please note that recently I noticed another user in the threads reporting the exact same problem.
We have about 20 Office 2010 installs, 20 to go. Emails received from 6 (so far) of those are occasionally (25% of the time?) received with portions of the body text corrupted. Sections of the text will be replaced with random characters, though it has the look of control code sequences so my guess is formatting gone bad.
Here's an example from the body of a received email:
"< p class= right now he probably won't be able..."
The original words preceding "right now" were replaced with "< p class =". More commonly the replacement text seems like random characters however.
The email that is received corrupted appears as un-corrupted in the sender's SENT box. We have numerous email clients doing the receiving -- ie. not just Outlook 2010 -- so I've ruled out it being a problem at the receiving end.
We run MS Security Essentials for AV on all desktops.
We've discovered that if we change the Compose message format from HTML to Rich Text it seems to reduce the nbr of incidents, but it does not solve the problem completely. I have also tried doing an uninstall/re-install, but it did not help.
Internal and external recipients both seem as likely to receive a corrupted email.
You're right, it's not MSE doing it because it doesn't scan mail. (It doesn't touch attachments until you open them.)
What type of email account? Is antivirus or content control software running on the server?
Did you test it in Safe mode? (Hold Ctrl as you click on the Outlook icon to start in Safe mode.)
Does rich text work ok internally but fail to external addresses? If so, that's because Outlook is converting the messages to html on send and whatever is going wrong, is happening after that.
N
Neil T Holland
What type of email account? <-- POP3
Is antivirus or content control software running on the server? <-- Incominng mail is hosted by a company with a Baracuda for AV/Anti-Spam. Not sure what the outgoing mailserver is running, if any.
Did you test it in Safe mode? (Hold Ctrl as you click on the Outlook icon to start in Safe mode.) <-- Will try. If it makes a difference, however, what next?
Does rich text work ok internally but fail to external addresses? If so, that's because Outlook is converting the messages to html on send and whatever is going wrong, is happening after that. <-- Rich Text failed on both internal and external addresses.
P Outlook for Mac - emails are not sent out beginning last week Using Outlook 1
T Outlook 2010 sent emails vanish Using Outlook 7
M How do you keep sent emails in the PST folder in outlook 2013 Using Outlook 1
D Outlook Archiving sent emails which have been moved to inbox folders Using Outlook 1
R Outlook 2010 Sent emails don't appear in the sent mail folder Using Outlook 9
N Configure Outlook 2010 to download sent emails Using Outlook 4
M Outlook doesn't save sent emails Using Outlook 1
D Do Outlook folders/emails still remain on the disk even if they've been deleted/sent to trash? Using Outlook 2
R Microsoft Outlook 2007 emails are sending but staying in Outbox &amp; send items are not in Sent box Using Outlook 2
G Add read receipt & opened links for sent emails - Outlook 2011 Using Outlook 2
L Outlook sent emails turn to dat file or winmail cannot be opened Using Outlook 1
V Outlook 2007 - Reply emails sent from wrong account Using Outlook 1
S Outlook 2003 (when looking at emails shows my name and not who sent the emails) Using Outlook 2
W Emails sent from Outlook, not saved in webmail. Using Outlook 1
O Outlook 2010: Rule to move sent emails doesn't start if I Use "Send To" command on a file on desktop Using Outlook 3
N Emails sent from Outlook 2010 are being received with some corruption of the body text Using Outlook 37
N Emails sent from Outlook 2010 are being received with some corruption of the body text Using Outlook 2
M I can receive emails. I reply or create a new e-mail and outlook shows it was successfully sent to the recipient. HOwever, the recipient never receive Using Outlook 2
N Emails sent from Outlook 2010 are being received with some corruption of the body text Using Outlook 5
J wireless always allows me to send/receive emails via outlook 2007. recent move to university gives me internet access but no emails can be sent or rec Using Outlook 1
D First email in outbox not going through in Outlook 2007; additional emails do get sent Using Outlook 10
M Missing headers in sent emails when showing in groups in Outlook 2003 Using Outlook 2
K Sent emails that were bounced back are missing, no where in outlook. Using Outlook 2
S Outgoing emails in Outlook 2010 are in duplicate but not shown in sent items Using Outlook 1
M OWA emails sent in firefox not readable in outlook Using Outlook 2
B Create a rule to move emails after being sent to specific domains Outlook 2007 Using Outlook 1
B just started up outlook 2010, initial startup problems...hangs up on deleting emails, won't file sent messages Using Outlook 4
N Outlook 2010, Emails are sent promptly but recipient gets only after long delay (45-60 minutes) Using Outlook 1
A Outlook 2007 not showing hyperlinks (in automated emails sent in plain text.) Using Outlook 11
A My Outlook stopped saving my sent emails to the Sent Items folder Using Outlook 3
F OUTLOOK 2010 SAVING SENT EMAILS ON EXCHANGE SERVER Using Outlook 2
V Emails remain in Drafts folder even though they have been sent Using Outlook 4
V Emails going into Drafts instead of Sent folder Using Outlook 3
S Emails Configured As HTML But Sent As Plain Text Using Outlook 13
M Emails being sent to Inbox and IPM_Subtree Using Outlook.com accounts in Outlook 4
D Emails do not appear in Sent box! Using Outlook 4
B Mass customized emails sent weekly Using Outlook 0
I Large emails not sent from correct account Using Outlook 0
R Track Sent Emails that have not been Responded Using Outlook 1
T Duplicate emails in different "sent" boxes. Using Outlook 2
K Clicking reply on sent emails TO field Using Outlook 2
S how to keep "To" when move sent emails to other folder Using Outlook 1
V Mark BCC when emails is sent from specific account Outlook VBA and Custom Forms 2
R Move sent items emails to hard disk Using Outlook 10
