Outlook was in use; when tried to open today it would not open; pop up with info about e-mails with macros; prompted to enable macros, when doing so;
W
WMcKenzie
Outlook was in use; when tried to open today it would not open; pop up with info about e-mails with macros; prompted to enable macros, when doing so; go thru process ends with
Error: WBA DLL
Russ Valentine
There is more to your story. State your Outlook version and the changes that occurred that lead to this problem. The error messages suggest you are running a version of Outlook that is not compatible with your operating system.Russ Valentine
N
Niyamath Khan
Which version of Outlook is installed on the computer?
What is exact error message which you get while opening Outlook?
Provide more information on the issue so that we can assist you in better way.
O Outlook 2016 0x800CCC0F 'The connection to the server was interrupted' Using Outlook.com accounts in Outlook 1
C Whose brilliant idea was to make it more difficult to scroll in Outlook? Using Outlook 0
D Will Outlook 2010 work with Office 2013 H&S that was preinstalled Using Outlook 2
E My Outlook 2010 contacts list was hijacked! Using Outlook 10
P Was Helvetica crashing Outlook, now fix has messed up explorer Using Outlook 4
G How to retrieve an email that was compacted in outlook Using Outlook 1
R No problems for about three months and the, about two weeks ago I was no longer able to receive emails in Outlook. Using Outlook 4
S Outlook 2007 SP2: When creating a future appoinment it shows day it was created not the future date Using Outlook 1
H Outlook Delegate gets "Can't open this item." when clicking on invites that she was the originator o Using Outlook 2
P Outlook says it's 'Sending' when it's opening. Nothing was in the Outbox for it to send. Using Outlook 2
T Outlook 2010 / SBS 2010 - User cannot view emails moved to a folder that was previously imported fro Using Outlook 6
A I have outlook 2010. I have received mail but can not locate mail that was down loaded. Using Outlook 2
O Outlook 2007: Invalid Entry ID was passed in (all email address gone) Using Outlook 1
B seting up office outlook...during set up, a box showed STMP POP3 for sending emails, the recieving box was empty. What information needs to go into t Using Outlook 2
M This is an Outlook email question. I need to know who may have recived my email that was sent to undisclosed recipients by mistake Using Outlook 3
H Outlook 2003 - can't send emails. Get this message from Norton Internet Security "was unable to be Using Outlook 2
M Cannot synchronize with the Outlook profile you are using, because a different profile was previousl Using Outlook 1
T Problem with Outlook 2007 (running Vista) There was an error synchronizing your folder hierarchy. Er Using Outlook 1
R I was syncing my phone and outlook and it seams that my phone created thousands of contact in outlook (A loop maybe) Using Outlook 1
C Outlook 07 opens, loads some emails, freezes (Vista) was working fine. Using Outlook 3
D Outlook 2007 reinstalled, but appointments don't show in To Do bar for new calendar that was created Using Outlook 1
M Not receiving an error code just not getting my e-mail in Outlook. I was picking up mail from Windows Live. I had someone send e-mail to all my contac Using Outlook 2
T Import Outlook 2003 .bcm file into Office 2010 Bus. Cont. Mgr. Error: "Input string was not in a cor Using Outlook 6
P the outlook 2007 calendar cannot be saved because it was changed by another user or in another windo Using Outlook 4
J Can't run macro Outlook 2007 that was created in Word 2007 Outlook VBA and Custom Forms 1
I Outlook 2003 shows html code when To: field is empty Using Outlook 5
C All Gmails don't show in Outlook 2019 Using Outlook 0
witzker Macro to move @domain.xx of a Spammail to Blacklist in Outlook 2019 Outlook VBA and Custom Forms 4
S Macro for other actions - Outlook 2007 Outlook VBA and Custom Forms 18
D Outlook 2010 Outlook in Windows 10 keeps asking for user name and password repeatedly Using Outlook 14
J How do I disable advertising in Outlook 2019? Using Outlook 13
