Outlook Printer Problem with Lexmark 205 wireless Printer__
socceral
Outlook Printer problem. I can not print to my Lexmark Pro205 from outlook. I was able to get a calendar page printed but nothing else. I can print from other office 2007 products but not outlook. It only appears to be a problem with my wireless Lexmark. I am running WINDOWS 7
I get this message if I click on Properties:
The properties dialog box is not available for the selected printer
I get this message if I click ok to print:
There was an error when printer started. To check the printer setup double click on the printer icon in windows control center
Ben M. Schorr [MVP]
How many OUTLPRNT files do you have on your hard drive? Should be in Documents and Settings\User\Application Data\Microsoft\Outlook.
socceral
I only have one outlprnt file. Also when I try to print to the printer from Outlook the status line is blank. Outlook is the only program I am having a problem printing. I am sorry for the delay in respondiing but I did not get a email that anyone had responded.
Ben M. Schorr [MVP]
Did it ever work? Do you have the most recent drivers installed for the Lexmark printer?
K Imap PC Outlook + Android phone Using Outlook 0
GregS Outlook 2016 Move Outlook to new computer? Using Outlook 2
I Outlook 2003 shows html code when To: field is empty Using Outlook 5
C All Gmails don't show in Outlook 2019 Using Outlook 2
witzker Macro to move @domain.xx of a Spammail to Blacklist in Outlook 2019 Outlook VBA and Custom Forms 4
S Macro for other actions - Outlook 2007 Outlook VBA and Custom Forms 19
D Outlook 2010 Outlook in Windows 10 keeps asking for user name and password repeatedly Using Outlook 14
J How do I disable advertising in Outlook 2019? Using Outlook 13
B Outlook Calendar not coming down from cloud Using Outlook 2
J Are the underlined letters in Outlook Reminders window supposed to work? Using Outlook 0
M Office 2016 Outlook is forgetting passwords Using Outlook 15
Wayne Outlook locks up when opening "Manage Rules & Alerts" Using Outlook 7
G Personal Settings within Outlook Using Outlook 2
V Outlook Forms: Formatting a Label with 2 different styles Outlook VBA and Custom Forms 1
M Outlook 2016 Outlook randomly unhides from taskbar Using Outlook 12
