convert VBA code to Add-in
bWFzYW5pIHBhcmVzaA
I have written simple VBA macro to delete recurrence meetings in
outlook(macro cod is given below). Could any one please tell me what is the
simplest method to convert this macro into Outlook Add-in such that it should
create button on Outlook toolbar and also register itself and start working.
Sub DeleteMeetings()
Dim olkItems As Outlook.Items
Set olkItems = Session.GetDefaultFolder(olFolderCalendar).Items
olkItems.IncludeRecurrences = True
For Each olkAppt In olkItems
olkAppt.Delete
Set olkItems = Nothing
MsgBox "Macro executed successfuly: " & Err
Paresh
K
Ken Slovak - [MVP - Outlook]
Using what development platform, language and Outlook version?
There is no VBA to addin converter, you first start with whatever platform
and language you want and set up a skeleton addin, then copy in your VBA
code and if necessary translate it into the language you're using.
If you intend to use managed code you will need to somehow shim your addin
so it has its own AppDomain, either using VATO or the COM shim wizard. If
using VB.NET you need to translate the code since VB.NET has many
differences from VBA code (for one thing Long is 64-bit and Integer is
32-bit). VB6 code is much closer to VBA code.
You then need to register your addin and deploy it as well as any
dependencies and prerequisites, such as the Framework for managed code.
"masani paresh" <masanip@deshaw.com> wrote in message
news:8C2E171E-4957-4801-9251-A0E6B3BD924C@microsoft.com...
> Hi,
> the
> should
> working.
> olkAppt.Delete
> Next
> End Sub
> > Thanks,
> Paresh
Q How tough is it to convert VBA to Addin Outlook VBA and Custom Forms 1
K Need to convert .mmf file to .pst format Outlook VBA and Custom Forms 4
M Convert Subject Line to Internet Header version of Subject Outlook VBA and Custom Forms 10
P How do I convert outlook “to-do” items to “tasks” Outlook VBA and Custom Forms 1
C convert an .ost to .pst Using Outlook 3
D The way to convert ost to pst Using Outlook 2
sneaky30 convert text to date Outlook VBA and Custom Forms 1
Diane Poremsky Convert an Offline File (.ost) to a Personal File (.pst) New Slipstick.com Articles 0
S How to do I convert OST file to PST? Exchange Server Administration 3
J convert .pst to .eml, how is it possible? Using Outlook 1
M convert/import a customized record into the default "Account" record BCM (Business Contact Manager) 0
V Check/convert to emailaddresses Outlook VBA and Custom Forms 11
R Convert Access table to pst Using Outlook 1
L Convert Distribution List of Contacts to Single Contacts Using Outlook 6
G Is there any way to convert outlook 2003 to outlook 2007 Using Outlook 5
D Outlook contacts no in address book - 2002 pst file convert to 2007 pst file? Using Outlook 0
A Outlook 2003: convert all RTF emails to HTML Outlook VBA and Custom Forms 1
J How to convert BCM contacts to normal Outlook contacts BUT... BCM (Business Contact Manager) 2
G Tasks - convert email to task & attach email Outlook VBA and Custom Forms 6
A Re: Convert Oportunity to Project? BCM (Business Contact Manager) 3
K can't get custom form to update multiple contacts using VBA Outlook VBA and Custom Forms 1
S Excel vba code to manage outlook web app Using Outlook 6
