I loaded Office Home and Business 2010 and Outlook will not load. I still have Outlook 2007
K
kyoung7500
What do I need to do to get Outlook 2010 to work. I just purchased and loaded Office Home and Business 2010 but my older version of Outlook 2007 is still rinning and I cannot find Outlook 2010 on my computer.
Russ Valentine
Better verify your version: Home and Business or Home and Student?Russ Valentine
K
kyoung7500
Hi Russ,
Thank you for your response. I definitely have Office Home and Business 2010. I just purchased and loaded it on my PC. Is there something I need to do to ensure Outlook 2010 loads? I entered the 25digit Product Key and followed all instructions. I have tried running repair and adding in all the software. It still comes back and says Outlook, not available. Is it possible I have been sent the wrong software in the Office Home and Business 2010 package? Thanks!
O The page that you are trying to access cannot be loaded. Using Outlook 0
R Custom Contact Form how to update when loaded. Outlook VBA and Custom Forms 6
M Outlook 2010 reloading messages that have already been loaded Using Outlook 3
N What is the recommended maximum amount of PSTs loaded for a user in Outlook 2010? Using Outlook 2
K I have 26 mail in my webmail which is not coming in Outlook 2010 when I open the program.__some mail from my webmail has been loaded into Outlook when Using Outlook 2
O I have 2003 outlook and am upgrading to 2010. Haven't loaded it yet but what do I do about existing files and messages on my 2003 Outlook Using Outlook 3
A I have outlook 2010. I have received mail but can not locate mail that was down loaded. Using Outlook 2
B just loaded outlook 2010 went to open it and just getting another box up saying Manged MAPI Service Catastrophic Failure. ( Eexption has beed thrown b Using Outlook 3
M The add-in could not be installed or loaded Outlook VBA and Custom Forms 1
F Outlook 2003 form cannot be loaded in 2007 Outlook VBA and Custom Forms 1
S Outlok 2007 add-in PJ Correspondence Log-How do I get it loaded? Using Outlook 7
J Emails stay in Outbox forever once addin is loaded Outlook VBA and Custom Forms 3
A BCM Database cannot be loaded BCM (Business Contact Manager) 2
A Out of Office Improvement Outlook VBA and Custom Forms 0
M Office 2016 Outlook is forgetting passwords Using Outlook 15
D Sending email from Office 365 alias in Outlook Using Outlook 3
J Office 365 erased all of my task views Using Outlook 3
P Categorize in Calendar not listed under tags in Office 365 (Office 2016) Using Outlook 5
L Deleting Office 365 calendar appt w/o emailing invitees Using Outlook 3
D Outlook 2016 Deleting emails without affecting folder structure - Outlook Office 365 Using Outlook 3
L Can signatures synch to Office Portal Using Outlook 1
T I'm thinking about moving from outlook.com to the Outlook I have in my Office 365 Using Outlook 1
Jennifer Murphy Outlook can't connect to Office 365 at resort hotel Using Outlook.com accounts in Outlook 1
J Outlook Office 365 Win 10 how do I control background colors of events? Using Outlook 1
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
J Migrate from godaddy 365 to office 365 home Using Outlook 8
Microfiche Migration from Office 2016 H&B to Office 365 Using Outlook 0
R How Can I backup office 365 account? Exchange Server Administration 1
O Office 365 Outlook - mark to download Using Outlook 0
T O365 and Office Message Encryption Exchange Server Administration 2
V Multiple Calendars in Outlook To-Do Bar; Office 365 Using Outlook 3
L Office 365 cloud based rules Using Outlook 1
T Office 2013 no longer updating automatically Using Outlook 2
O Office 365 - Outlook - Password protect your mailbox Using Outlook 7
Horsepower Office Outlook 365 home opens slower than a month ago Using Outlook 8
