Uninstalled Office 2007 and installed Office 2003. Unable to work with Outlook.
C
CABinoxted
We have a new PC installed with Office 2007, but we wish to continue to use 2003. We have uninstalled 2007. Excel 2003 now works after it reinstalled itself. Outlook 2003 no longer works on this PC but still works on other PC's that have not had the modification. It worked immediately prior to the above action.
Ben M. Schorr [MVP]
You can't have two versions of Outlook installed side-by-side in the same OS instance. Excel, Word and most of the other office apps don't mind, but Outlook does.
H
Hal Hostetler - Print-Imaging [MVP]
Here's more info on downgrading Outlook:
Downgrading Outlook and backwards compatibility
MAPI32.DLL error after clean install Hal
C
CABinoxted
Thanks Russ,
I removed and then reinstalled Office 2003. The email account suddenly worked with all the previous messages in the inbox and no need to recreate the account.
Many thanks for your assistance.
Mike
M Social Connector installed, uninstalled, now install crashes Outlook Using Outlook 3
A Out of Office Improvement Outlook VBA and Custom Forms 0
M Office 2016 Outlook is forgetting passwords Using Outlook 15
D Sending email from Office 365 alias in Outlook Using Outlook 3
J Office 365 erased all of my task views Using Outlook 3
P Categorize in Calendar not listed under tags in Office 365 (Office 2016) Using Outlook 5
L Deleting Office 365 calendar appt w/o emailing invitees Using Outlook 3
D Outlook 2016 Deleting emails without affecting folder structure - Outlook Office 365 Using Outlook 3
L Can signatures synch to Office Portal Using Outlook 1
T I'm thinking about moving from outlook.com to the Outlook I have in my Office 365 Using Outlook 1
Jennifer Murphy Outlook can't connect to Office 365 at resort hotel Using Outlook.com accounts in Outlook 1
J Outlook Office 365 Win 10 how do I control background colors of events? Using Outlook 1
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
J Migrate from godaddy 365 to office 365 home Using Outlook 8
Microfiche Migration from Office 2016 H&B to Office 365 Using Outlook 0
R How Can I backup office 365 account? Exchange Server Administration 1
O Office 365 Outlook - mark to download Using Outlook 0
T O365 and Office Message Encryption Exchange Server Administration 2
V Multiple Calendars in Outlook To-Do Bar; Office 365 Using Outlook 3
L Office 365 cloud based rules Using Outlook 1
T Office 2013 no longer updating automatically Using Outlook 2
O Office 365 - Outlook - Password protect your mailbox Using Outlook 7
Horsepower Office Outlook 365 home opens slower than a month ago Using Outlook 8
J Office 365 - Online Repair vs. Uninstall Reinstall Using Outlook 1
O Backup Office settings - registry key Using Outlook 5
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
J Out of Office, Delegate Using Outlook 1
H Custom autoforwarding, sending mail through outlook office 365 Using Outlook 1
e_a_g_l_e_p_i Just had to reinstall window 10 then Office and forgot how to control fonts sizes Using Outlook 3
B Search function in Office 365 has stopped working Using Outlook 3
L Outlook Office 365 cached mode crashing Using Outlook 0
P Oulook addin unloaded in office 2007 Outlook VBA and Custom Forms 2
Fozzie Bear Office 365 Home Premium with Exchange Online email accounts Using Outlook 3
mrje1 Outlook 2016 Manual Email Account Setup, what is the Office 365 option etc., and Crashes Using Outlook 0
