Messages take long to appear, rules (here they come again) don't work, sent messages aren't saved
F
Fabricio Pub
I made a decision to switch from web browsing to Outlook 2010 for accessing my emails on my Gmail account, expecting greater tools and greater control. But, so far, I must say I've had a quite frustrating experience!!
1) After Send/Receive finishes, the messages don't appear instantly on my Inbox. Instead, they keep coming, one by one, slooowly, and there is absolutely *nothing* on the screen to inform me whether there are still messages "coming" or not. So I basically have to wait until I guess it has finished. I'm on a 2-core 2.53ghz 4GB DDR3 running Win7Pro pretty smoothly. Is that really how Microsoft wanted the user experience to be?
2) Rules have really been the most frustrating thing. I have a message from a YahooGroup in my Inbox. I right-click it, then chose to create a simple rule "Always move messages from groupx@yahoogroups.com to folder GroupX". But next time I get a message from that group, it remains on my Inbox instead of going to folder GroupX. I've already tried:
a) Manually creating the rule instead of right-clicking the example message;
a) adding/removing the "Stop processing more rules" part of the rule;
b) adding/removing the "On this computer only" part of the rule;
...but nothing seems to get Outlook to move the message away from Inbox. I've already read on the web that there is something to server-side VS client-side rules, which I "think" I understand but am unable to reason towards a practical solution. All I want is the message from a specific sender to be moved to a specific folder in my computer. Would anyone be so kind as to give me a reasonable explanation on why such a simple task is so hard to configure?
3) I have the option "Save copies of messages in the Sent Items folder" checked. But none of my sent mails get saved. I have to resort to web browsing to see my sent mail. Is there anything I'm missing?
Thanks a lot in advance for all the support!
Fabricio
F
Fabricio Pub
Just one more piece of information on issue 2: I've also tried creating a rule "Always move messages _sent to_ groupx@yahoogroups.com to folder GroupX", with no good results.
Thanks a lot.
Raju S Das
How is the Gmail email account configured in Outlook, as a POP account or an IMAP account?
Raju S Das
Are you trying to move the emails to the subfolder which is in the personal folders list or to the IMAP folders list?
F
Fabricio Pub
On my navigation pane I have two "roots": "Outlook Data File" and "myemail@gmail.com". After Send/Receive finishes, the messages appear under the "All" folder in myemail@gmail.com (the folder which gets all mail in Gmail), and I'm telling the Rule to move them to the GroupX folder under Outlook Data File. So I'm guessing it is a personal folder, not IMAP folder. I hope I'm clear on my explanation.
Raju S Das
Check the radio button mentioned in the below steps and verify the status.
Open Outlook> File> Options> Advanced> Send/receive >Edit>
Download complete items including attachment for subfolders and then check if the rule works.
F
Fabricio Pub
Hi Raju,
I did as instructed, and then tried to perform a Send/Receive.
It seemed to work, as in, some messages *did* get moved like I always wanted... but Send/Receive would never finish. It stucked at like 70%, and didn't move after that.
Maybe it its trying to download aallll mail in my Gmail account?
Thanks a lot for the help!!
F
Fabricio Pub
This Send/Receive freezing problem was something I had earlier. Changing the configuration to "Use the custom behaviour defined below", selecting my "All mail" folder, and chosing "Download headers only" was what made it stop freezing.
But this seems to also be what makes Send/Receive *not* work, in the sense that clicking my Inbox, under the "myemail@gmail.com" root in Outlook, does what I would expect Send/Receive to do: receive all mail and apply rules to organize them into local folders.
This is really weird. I must admit I am quite frustrated with Outlook 2010 after several *months* trying to fix problems that I can't even understand why they ever happen. All I wanted was to click Send/Receive and watch Outlook get my messages from Gmail and put them into appropriate local folders. So far I couldn't achieve this.
G Opening messages takes too long Using Outlook 5
S Customize the autocolor font choices for replying/forwarding messages Outlook VBA and Custom Forms 0
S Conditional Formatting for messages in a Conversation thread Using Outlook 1
GregS Outlook 2016 Sent Items vs Sent Messages Using Outlook 2
snissen Printing foreign language messages Using Outlook 1
S Receiving duplicate messages from RSS feeds Using Outlook 3
R Can't send messages to groups in Outlook Using Outlook 2
icacream outlook keeps neither SENT or FORWARDED messages... they vanish ! Using Outlook 4
W Receiving messages in offline mode Outlook VBA and Custom Forms 1
RangerRick Text Extraction from forwarded messages external Exchange Server Administration 1
L How to use different fonts for outgoing messages for different email accounts Using Outlook 0
T SMTP messages stuck in Outbox Using Outlook 0
Mark White VBA to deal with Recalled messages Outlook VBA and Custom Forms 7
O Rules and Alerts for New Messages BEFORE sending Using Outlook 2
Liza Creating a rule in outlook to filter messages Using Outlook 0
S Automatically selecting folders and deleting messages in Outlook VBA Outlook VBA and Custom Forms 7
Diane Poremsky Save Messages and Attachments to a New Folder New Slipstick.com Articles 0
P AOL messages Outlook VBA and Custom Forms 0
Diane Poremsky Create a custom field for Outlook messages New Slipstick.com Articles 0
I Identify Number of email messages opened Outlook VBA and Custom Forms 7
Diane Poremsky Monitor secondary mailbox folder for new messages New Slipstick.com Articles 0
Diane Poremsky After viewing the Outbox, messages won't send New Slipstick.com Articles 0
Diane Poremsky Create a Custom Numbering Field for Outlook messages New Slipstick.com Articles 0
Diane Poremsky Remove Attachments From Messages New Slipstick.com Articles 0
C Changing the name of Outlook Messages saved to a folder Using Outlook 1
S Outlook 2013 doesn't download html messages Using Outlook 0
Diane Poremsky Search for All Messages from Contact and Display in New Window New Slipstick.com Articles 0
Diane Poremsky Delay Delivery of Messages Sent at Specific Times New Slipstick.com Articles 0
Diane Poremsky Reusing Sent Messages New Slipstick.com Articles 1
S Empty an Office365 public folder containing 20.000 messages Using Outlook 2
C Discovery search does not show autoforwarded messages Exchange Server Administration 1
Diane Poremsky Add a file number or keyword to the subject line of messages New Slipstick.com Articles 0
O How to delete duplicate RSS messages? Using Outlook 6
