Add read receipt & opened links for sent emails - Outlook 2011
G
Gayala2010
Hello-
How do I add a 'read' receipt by for sent emails and 'opened' receipt for opened links in sent emails? I'd like to know when my sent emails are opened up and when included links are clicked on.
Gerard
H
Hal Hostetler - Print-Imaging [MVP]
Outlook 2011? Perhaps you have Outlook 2010... 'File tab|Options|Mail|Tracking', you can set for both read and delivery receipts (which the receiver can ignore if he cares to, unfortunately). To the best of my knowledge, there is no such thing as a " clicked link" receipt available in email.Hal
If you are using Mac Office 2011, have you checked mac forums such as http://officeformac.com/ProductForums/ ? We're Windows here and while we can answer simple mac questions, a forum dedicated to mac's and supported by mac users is likely to be better.
B Task Filter Not Working When I add too many criteria Using Outlook 0
D Add Tetxbox at form open Outlook VBA and Custom Forms 1
Andrew Quirl Open attachment, manipulate without add-on program? Outlook VBA and Custom Forms 5
B Searching for a Add-In Using Outlook 3
J Add Fillable Fields to Existing Template Outlook VBA and Custom Forms 1
J vb to c# for Outlook add-in. Using Outlook 0
twofivepie GTD Netcentrics add-in for 2016 Outlook VBA and Custom Forms 13
D Add all meeting rooms to the meeting request by default Outlook VBA and Custom Forms 0
A add birthday to outlook contacts Using Outlook 1
