Quick Tasks - Finish/Save Button Does not Work
ryzerman
I'm trying to create and edit Quick Tasks. I'm discovering that when I use e-mail addresses from our global address list, the quick task will not allow me to click SAVE or FINISH. If I use another e-mail address (not from our global) it works.
Has anyone see this before?
ryzerman
We currently don't use Exchange. (we will soon) Should I still post there?
Sachin Shetty
No.
So from where are you accessing the global address list?
No.
if this is the quick steps address bug, the "global address book" dialog only comes up for non-Exchange users. (It works correctly for Exchange users. )
ryzerman
So to clarify this will not work for non-exchange users?
I also have a new problem. When I started trying to use this feature, I selected theTO: box to select a name but the global address list was blank. On this dialogue box there is a button calledNew Contact. I clicked and created two people.
I cannot find anyway to delete these new contacts. They're not in my contacts either?
Any suggestions on where these are located?
ryzerman
I cannot find anyway to delete these new contacts. They're not in my contacts either.
I'm still hoping someone can help me with this last post.
Thanks for all your time.
A Quick Steps in Tasks view Using Outlook 7
C Further automate several tasks with rule, VBA or Quick Step Using Outlook 1
G How to add a folder shortcut to outlook quick access toolbar? Using Outlook 5
M font format discrepancies with Quick Parts Using Outlook 1
Diane Poremsky Synchronize Quick Access Toolbar and Ribbons? New Slipstick.com Articles 0
C Quick Parts signatures suddenly require more letters Using Outlook 2
S Save in folder other than Sent when replying with Quick Steps Using Outlook 5
R Missing Quick Steps and Rules Using Outlook 0
J quick quesiton about outlook search Using Outlook 3
iwshim Skype tool bar in quick access ribon Using Outlook 1
B How can I adjust the ribbon width? I want to see all of my Quick Steps. Using Outlook 1
L Quick step to fill custom field Outlook VBA and Custom Forms 1
B Push Quick Parts to All Users Using Outlook 1
adaminaus Quick question if i may Using Outlook 4
L Outlook Data Files command not working in the quick access bar Using Outlook 1
S New Quick Step based on Team email QS - automatically update too Using Outlook 1
L Outlook 2010 Quick Print Attachment, nothing happend Using Outlook 0
B quick help with "changed by" field in a shared mailbox?? Using Outlook 3
A Recommend add-on or utility enabling quick Google search within Outlook Using Outlook 7
J Outlook 2010 using Quick Print to print attachments Using Outlook 1
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
S Quick Search will not work due to itemizing Using Outlook 1
D Quick Parts - font changes Using Outlook 6
D Quick Parts - font changes Using Outlook 0
S Inserting Dates With Quick Parts (or Macros) Using Outlook 4
S Quick Parts - Changing Display and Order Using Outlook 0
E Blank Print Preview when access via the Quick Access toolbar Using Outlook 3
D How do I get a new mail icon into my quick launch bar? Using Outlook 3
K Quick Print shows wrong date on Occurrences Using Outlook 1
M Quick Parts text disappears Using Outlook 1
J Quick Exchange 2010 install ? Exchange Server Administration 2
R Outlook 2010 Quick Steps - Mark as Read Action and New Mail Notification Using Outlook 1
M Quick steps: feature request: 'direct replies to' when forwarding Using Outlook 1
T Quick start mass e-mail Using Outlook 1
R sending mail from applications like quick books Using Outlook 1
R Outlook Calendar - Directly typing in to quick-create reservations often get cut off. Buggy. Using Outlook 1
H getting a quick view of contact groups? Using Outlook 4
G Office 2010 Quick Contacts option not available in To-Do Bar Using Outlook 1
I Outlook 2010 Quick Steps Don't Save (Global Address Book) Using Outlook 3
L Getting a quick information about an addressee in the outlook Using Outlook 1
