Reading Pane text appearing all the way to the right...
Rogsi
I have a friend at work who uses MS Outlook 2007 to send and recieve her emails. When she creates a new email it automatically adjusts her text prompt to the right. Is there a way to fix this? Also, when she recieves some of her emails they appear the same way.
Roady [MVP]
Locate normalemail.dotm and rename it to .old when Outlook is closed.
By default it is located in;
C:\Documents and Settings\%username%\Application Data\Microsoft\Templates
E Reading Pane has disappeared Using Outlook 1
Diane Poremsky Excel Files Won't Display in Reading Pane New Slipstick.com Articles 1
M Outlook 2007: how to narrow the reading pane and the composing pane Using Outlook 0
T Outgoing Messages in the Reading Pane Cannot Be Flagged in Outlook 2013 Using Outlook 6
F Outlook 2007 - Reading Pane Automatically Downloads First/Topmost Message Using Outlook 4
C Contact photos not showing in reading pane in Outlook 2013 Using Outlook 3
T Killing reading pane - "globally" Using Outlook 11
M Viewing Custom Form Fields in the Reading Pane and in Replies Using Outlook 3
D Cursor in reading pane Using Outlook 5
J Outlook 2010 reading pane option - want to permanently adjust the zoom setting. Using Outlook 13
S Outlook 2010 reading pane not clearing Using Outlook 3
S Macro for Viewing mails one after the other in the Reading Pane Outlook VBA and Custom Forms 2
E CustomTaskPane in PLace of Reading Pane Outlook VBA and Custom Forms 3
T Blank Email in Reading Pane for Custom Form Outlook VBA and Custom Forms 12
C Getting reading pane horizontal instead of vertical Using Outlook 2
Y View Reading Pane for Drafts folder Using Outlook 2
V Reading/Posting in Newsgroups Using Outlook 1
A Received Date None after reading Using Outlook 2
P exchange management consoles has stoped working and yes I have read the above article and tried the troubleshooter and spent days reading and trying d Exchange Server Administration 0
M Reading .msg Messages In MS Outlook For Mac 2011 Using Outlook 1
C Change default reading font in Outlook from Times New Roman 12 point to Arial Using Outlook 2
B Reading CompressedRichText field in SQL database BCM (Business Contact Manager) 1
L Windows Instant Search Indexing not working need help reading Event Log Using Outlook 2
B Huge characters when reading some mails Using Outlook 42
A Outlook 2010 keeps closing and restarting when reading messages Using Outlook 12
R Proof Of Looping Bug in Reading Outlook Inbox From Access? Outlook VBA and Custom Forms 2
L Reading another mailbox Address Outlook VBA and Custom Forms 2
N Reading Recipients in a folder Outlook VBA and Custom Forms 1
