MS Outlook 2010, 2 questions, 1 about pasting and 1 about sending
MSGOLDFAIN
I am fairly new to using MS Outlook 2010. (Details: Microsoft Office Professional Plus 2010, Outlook version 14.0.4760.1000 32-bit; I'm using it under Windows 7 Professional on an Intel 64-bit machine).
I create some reports on a system that gives them to me in plain text. I paste these into the body of my Outlook message as a report. No problem, I use Courier New font, so everything is fixed-width, and paste them as just text. However, I send the email as HTML.
Problem 1: Whenever I paste more than one line, everything after the first line is pasted in with a slight indent. This is a little annoying, but I can easily correct it by selecting everything and formatting the paragraph, and settingf the indent to 0. Is there any way to stop this behavior so I don't have to keep correcting it?
Problem 2: This is more annoying. Many of my lines in the report section and even in my own typing are indented by beginning them with leading spaces. With a fixed-width font, it is easy to do your own paragraph/table/outline indents, simply by putting spaces at the beginning of the line. But after I send, in most places, a first space is removed from every line of the email. I'm not sure if it is removing this from every line that begins with a space or just most of them. If a line begins with n spaces, only the first space is removed, so it now begins with (n-1) spaces when my report is received by others. IT makes it look like I messed up the alignment! Any ideas on this?
E
Ezil Vinoth
Try the steps given below and check if it helps:
1. Close all Word documents and Outlook
2. Open Run window (press and hold Windows key + R) then copy and paste the following text
3. C:\Users\es\AppData\Roaming\Microsoft\Templates
4. Right click on Normalemail.dotm and rename to Normalemail.old
5. Now try to paste.
If these steps did not resolve the issue create a new profile for Outlook and verify the status.
T Outlook 2010 Mutliple Exchange Accounts SET UP QUESTIONS Using Outlook 4
D 3 Easy Questions for Gurus on Word 2007 and Outlook 2010 Using Outlook 11
I Outlook 2010 questions, Mass import into contact group, cull duplicate addressbook entries, alphabet Using Outlook 1
T Why does outlook 2010 convert only some forum notifications to plain text? Using Outlook 2
