Items in MSN Hotmail inbox will not migrate to Outlook inbox
H
Hal Hostetler - Print-Imaging [MVP]
A little more information, please. Do you have only a Hotmail account? Are you using the Outlook Hotmail Connector?
Hal
B oContacts.Items.Restrict Misses Some Contacts Outlook VBA and Custom Forms 1
A Connect to server to views items Using Outlook 0
D Mail in Sent Items Gone Using Outlook 12
GregS Outlook 2016 Sent Mail absent from Sent Mail or Sent Items Folders Using Outlook 4
T Increasing the number of items that appear on the Categories list Using Outlook 2
King Mustard Sort search groups by amount of items? Using Outlook 1
C Pull Outlook shared calendars items from Excel Outlook VBA and Custom Forms 4
J Outlook Reply > From > Other Email Address... > Address Not Showing in Sent Items... From Email Outlook VBA and Custom Forms 0
GregS Outlook 2016 Sent Items vs Sent Messages Using Outlook 2
M Sent mail not showing in Sent Items folder; but they can be found with Search Using Outlook 3
A Order of Recent Items in Attach File List Using Outlook 5
O Outlook 365 - Toolbar - Close all items - missing? Using Outlook 3
B Clear Offline Items (Mail Folder) via VBA Outlook VBA and Custom Forms 1
A Move email items based on a list of email addresses Outlook VBA and Custom Forms 40
R Retention periods and Deleted Items Using Outlook 7
V Items missing in Sent folder Using Outlook 10
P Deleted Items - Unable to Iterate All of Items Outlook VBA and Custom Forms 1
P How do I convert outlook “to-do” items to “tasks” Outlook VBA and Custom Forms 1
N Tracking Mail items being moved to folders Outlook VBA and Custom Forms 5
icacream Can't the Deleted Items Folder be self cleaning ? Using Outlook 2
N Selecting multiple calendar items Using Outlook 4
M Sent Items Folder is Present but Not Displayed Using Outlook 2
B Saving items under a folder Using Outlook 3
M Outlook.com autocomplete list invaded by strange items Using Outlook.com accounts in Outlook 7
O How to display number of items per .pst file Using Outlook 7
S Show Total Number Of Items Not Displaying Using Outlook 9
M How many days are items in Recover Deleted at Outlook.com ? Using Outlook.com accounts in Outlook 4
A Cant See outbox items on a secondary Account Exchange Server Administration 3
J How do I get the items in a collapsed group? Outlook VBA and Custom Forms 12
J Accessing calendar items for Resource Mailboxes Outlook VBA and Custom Forms 2
S How to extract mail items from multiple folders and shared mailboxes? Outlook VBA and Custom Forms 0
C Color Code New Calendar Items Using Outlook 2
C Outlook is permanently deleting deleted items (purging) Using Outlook 0
F Move mails from Deleted Items folder back to its original folder where the mails got deleted Using Outlook 0
