Outlook 2003 thinks I'm connected to and exchange server. I'm not. How do I reset
Tinker47
Outlook 2003 thinks I'm connected to an exchange server, but I'm not. How do I reset?
G
Gordon B-P
Either remove the spurious exchange server account on Control Panel-Mail-Email accounts (with Outlook closed) and replace with your correct account, or if that doesn't work, create a new mail profile in the same place....and this time read the account setup dialog!
O Duplicate folders in Outlook 2003 Using Outlook 3
O Moving OUtlook 2003 from bad XP to Win 7 Pro 64 -- URGENT! Using Outlook 8
R Menus in a new\old email not there in Outlook 2003 Using Outlook 2
R OUTLOOK 2003 on WinXP, Prob: CONTACTS or ADDRESS BOOK not connected or missing Using Outlook 6
R Outlook 2003 not working Using Outlook 13
C Outlook 2003 displays wrong account in IMAP Using Outlook 5
K outlook 2003 address book Using Outlook 25
J Outlook 2003 freezing when clicking on TO button Using Outlook 2
