Outlook 2003 does not work in window 7
B999
I installed both outlook 2003 (office 2003) and office 2007. My conputer is Dell inspiron and has window 7 already installed in it. I saw some message that window or office was not correctly installed. What shoud I do? I followed Gmail instruction regarding IMAP. What should I do?
H
Harry Yuan
Outlook 2003 as well as Outlook 2007, both are compatible with windows 7, but it's recommended to use Outlook 2007 for better performance.
For compatibility, check
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Search.aspx?type=Software&s=Outlook%202003 .
If you want to continue with Outlook 2003 then update it with service pack 3.
Find service pack 3 for Outlook 2003 at
http://www.microsoft.com/downloads/details.aspx?FamilyID=E25B7049-3E13-433B-B9D2-5E3C1132F206&displaylang=en .
Hope this helps.
Regards,
Harry
Fozzie Bear How does Outlook 2003 deals with IMAP configuration Using Outlook 8
J Does Outlook 2003 run on Windows 8 Professional? Using Outlook 2
J Outlook 2003 does not send or receive imap mail from server Using Outlook 0
E Outlook 2003 changing appointment date or time does not update on calendar Using Outlook 5
P Addressbook Outlook 2003. I am Using Vista with Office Professional Edition 2003.__I tried everthing to safe the addressbook to a CD but it does not w Using Outlook 1
M Upgrading from Excahnge 2003 to Exchange 2010 how does it effect outlook client users Exchange Server Administration 7
M Outlook 2003/2007/2010 not showing attachments but OWA does Using Outlook 6
J EX2010 to 2003 does not work with Outlook but does with OWA Exchange Server Administration 2
J Outlook 2010 does not show some messages after upgrade from Office 2003 to 2010 Using Outlook 1
T Outlook 2003 incoming HTML does not display correctly Using Outlook 1
D Why does my Outlook 2003 .Com Add-In disappears after reboot! Outlook VBA and Custom Forms 4
N VBScript does not run in Outlook 2003 Outlook VBA and Custom Forms 4
B Outlook 2007 Custom Form does not display in 2003 Outlook VBA and Custom Forms 3
