Outlook 2010 crashes using XP SP3
  • Thread starter Outlook 2010 crashes
  • Start date
O
Upgraded OL 2003 to OL 2010 on my XP SP3 desktop. Everything was working well for months until this morning.
Outlook2010 crashes after about 20 seconds. It receives e mail and if I am quick can do anything. Anything you can do in under 20 seconds:)
Same result in SAFE mode on OL2010. Tried to repair from the DVD. It got through the repair process but the issue persists. In Event Manager I have the following error:
Faulting application outlook.exe, version 14.0.4760.1000, stamp 4ba8fefd, faulting module outlook.exe, version 14.0.4760.1000, stamp 4ba8fefd, debug? 0, fault address 0x00014354.
Can anyone help. I am getting frustrated. thanks
TWHarrington
Have you installed any add-ins lately? I would start by deleting and recreating the Outlook profile. If that doesn't work, you might need to uninstall and reinstall the application.
O
I loaded blueant updater but the uninstalled it after I used it, right before the problem began last night. I purchased the OL2010 upgrade online and I got a disc as well but I am afraid to uninstall as the installation program is somewhere in Outlook and I can't find it in 20 seconds or less. The disc I have appears only for uninstall and repair.
Any other options?
O
I tried to uninstall OL2010 with the disc from HUP but it failed and said I needed admin privileges even though this is my home computer and I am the admin. Tried again to repair after the uninstall failed, was asked and re input my key which I did and when OL came back up it failed the same way after 20 seconds.
U outlook 2010 freezes/crashes when opening encrypted e-mails Using Outlook 0
R Outlook 2010 Crashes from the Global Address List Using Outlook 1
S Re: Outlook 2010 crashes when upgraded from Office 2007 Using Outlook 1
T Outlook 2010 crashes when upgraded from Office 2007 Using Outlook 1
E Outlook 2010 - Calendar crashes Using Outlook 2
D Outlook 2010 Client crashes on new message, reply, forward, send as attachment Using Outlook 3
P Outlook 2010 Crashes Using Outlook 1
P Outlook 2010 Crashes Constantly Using Outlook 4
D Outlook 2010 crashes when I select new message, reply, forward or send as attachment Using Outlook 3
L Outlook 2010 Crashes Using Outlook 1
R Outlook 2010 crashes when trying to access signature Using Outlook 1
S Outlook 2010 Crashes consistently on second reply to an email ... (Release, and not Beta version) Using Outlook 1
S Outlook 2010 (32bit) crashes on Windows 7 (64bit) when I view desktop Using Outlook 12
J Getting message crashes in Outlook 2010 Using Outlook 11
S Outlook 2010 crashes when clicking on new message or reply Using Outlook 3
B Outlook 2010 crashes at startup Using Outlook 6
P Outlook 2010 calendar crashes when opened Using Outlook 11
D Outlook 2010 crashes after clicking the reply button (second time) Using Outlook 6
B OUtlook 2010 crashes every time Reply, Repply All or Forward is pressed. Using Outlook 3
B Outlook today page crashes Outlook 2010 with default pst file Using Outlook 26
D OUTLOOK 2010 crashes trying to print any e-mail with HTML formating. Using Outlook 5
T Outlook 2010 crashes when opening certain emails Using Outlook 17
M Outlook 2010 Crashes When Loading Add-Ins Using Outlook 6
S Outlook 2010 crashes upon opening email Using Outlook 11
E Outlook 2010 crashes when creating (reply) a message from a Meeting Using Outlook 6
