Microsoft Outlook 2010 Instant Search Encountered a Problem While Trying to Display Results.
W
W Schott
I just upgraded to Office 2010 from Office 2007 and when I am in Outlook, contacts, mail, and calendar.....the instant search encounters a problem and display this message: Instant search encountered a problem while trying to display results. Modifying your query may resolve the problem. I am running on Windows Vista Home Premium and Office 2010. Please help!!!!!
Jennifer Zhan
There are a couple of levels at which Instant Search can break. You can troubleshoot Instant Search in following methods:
Marked for indexing
File-> Options-> section Search-> button Indexing Options…-> button Modify-> expand Microsoft Outlook
In the list that is shown under Microsoft Outlook, make sure that your pst-file is displayed and selected. If it is not listed, you"ll have to recreate your mail profile.
Check for pst-file corruptions
If your pst-file has been marked but Outlook doesn"t display the correct results, it usually means there is some corruption going on in your pst-file. In order to fix these you should scan your pst-file for errors with scanpst.exe. You can find this file in the same folder as outlook.exe or use OutlookTools (free!) to locate it for you.
For Outlook 2010 you must click in the Search field in order to make the Search Tools tab visible in the Ribbon. Here click the Search Tools button and select the Indexing Status…
Disable and then re-enable the file for indexing
Go back to the Search Options and deselect the data file that is giving you issues. Close Outlook and wait for about 5 minutes and also verify in Task Manager (CTRL+SHIFT+ESC) that on the Processes tab the outlook.exe process actually quits. You might get a lot of disk activity; this is the Search Indexer removing the indexed items from the Index.
After this open Outlook again and go back to the Search Option and select the pst-file we just deselected. Leave the computer idle again and see if it will eventually reach the status of " 0 items remaining."
Rebuild the index
If it doesn"t, it might be that the Index itself has been damaged. In order to reset this, go to Control Panel-> Indexing Options-> Advanced-> button Rebuild
This will rebuild the entire Index from scratch and depending on the amount of documents to be indexed, this could take quite long and degrade your system"s performance while the Indexer is still busy. I would recommend to have it rebuild itself overnight.
Hope that helps.
R Microsoft Outlook 2010 - Non Cached Mode Using Outlook 0
Angger Microsoft Outlook 2010 Automatically Restarting Using Outlook 2
G Microsoft Outlook 2010 Add-On Using Outlook 2
W Microsoft Mail & 2010 Outlook Using Outlook 1
I Send Secure Email Through Microsoft Outlook 2007 and 2010 (32 bit) Using Outlook 0
D Outlook 2010 won't launch after installin Microsoft office 2010 service pack 1 Using Outlook 1
P Outlook 2010 and Microsoft Setup Bootstraper... Using Outlook 1
C Microsoft Office Outlook 2010, Windows 7 Using Outlook 2
W To stop outlook 2010 to open my browser at file:///C:/Users/username/AppData/Local/Microsoft/Windows Using Outlook 1
W Microsoft Outlook 2010 Using Outlook 2
S Re: Microsoft outlook 2010 Auto reply not working on a POP based account Using Outlook 3
F I cannot highlight text in Microsoft Outlook 2010 e-mails, and copy/paste to the body of another e-m Using Outlook 3
J Outlook 2010 Microsoft exchange server to pop account type switch? Using Outlook 2
V Use Microsoft Outlook 2010 over authenticated proxy Using Outlook 5
L Cannot change my setting on Microsoft Outlook 2010 from IMAP to POP. Using Outlook 1
M iPad does not Sync with Microsoft Outlook 2010 Contacts, Calendar, Etc. Using Outlook 2
B Sending duplicate text messages via Microsoft Outlook 2010 Exchange Server Administration 12
M BTYahoo Mail and Microsoft Outlook 2010 Using Outlook 3
B Microsoft outlook 2010 + iphone Using Outlook 1
F Unable to open microsoft outlook 2010 Using Outlook 2
N microsoft outlook 2010 Using Outlook 1
R Microsoft Outlook 2010 Auto Fill Feature Using Outlook 1
B Outlook 2010 unable to connect to a remote Microsoft Exchange 2003 server Using Outlook 8
T Microsoft outlook 2010 reports mail box is full Exchange Server Administration 2
H Problem with "User Account Control" on Microsoft Outlook 2010 Using Outlook 1
T I have Office Professional 2010 and Microsoft Outlook has stopped working Close the Program__ Using Outlook 2
U 'Cannot Start Microsoft Outlook' when trying to start oullok 2010 Using Outlook 2
J Microsoft Outlook 2010 keeps freezing Using Outlook 1
J Cannot start Microsoft Outlook 2010 a second time Using Outlook 4
J "Clip" icon appear in Microsoft Outlook 2010 / Exchange 2007 OWA Message, but no attachment inside Using Outlook 4
T Microsoft Outlook 2010 problem Using Outlook 4
H Outlook - Meu Microsoft Office professional plus 2010 (Tecnical Preview) Expirou Using Outlook 1
R windows 7 and outlook 2010 microsoft security username and password request Using Outlook 10
E My Microsoft Office 2010 Beta version has expired. How do I backup my Outlook contacts and email bef Using Outlook 1
T "Microsoft Outlook has stopped working" error message in Office 2010 Trial Using Outlook 6
H outlook express to microsoft outlook 2010 Using Outlook 1
H Re: outlook express to microsoft outlook 2010 Using Outlook 2
G Where does Microsoft Outlook 2010 save my information and configurations? Using Outlook 1
J Microsoft outlook 2010 on windows 2003 Server. Using Outlook 1
N Search multiple mailboxes with a "Search Folder" in Microsoft Outlook 2010 Using Outlook 1
T Microsoft Outlook 2010 Error "Another version of Outlook is currently running." when clicking on a m Using Outlook 1
D Microsoft Outlook 2010 Using Outlook 2
J Microsoft Outlook 2010 Contact Phone Number Region/Country Using Outlook 3
J Cannot connect Outlook 2010 to Microsoft Exchange 2000 Using Outlook 2
A my microsoft outlook 2010 trial is not sending/receiving emails Using Outlook 1
N microsoft outlook 2010 Exchange Server Administration 5
W Error Message Office 2010 'the connection to microsoft exchange is unavailable. Outlook must be online or connected to complete this action' Exchange Server Administration 1
A Where are the Step by Step Microsoft outlook 2010 practice files? Using Outlook 3
R Microsoft Office Outlook 2010 Email not working!__ Using Outlook 1
