aoutlook 2010 sent from is not using default imap
MAASKE
I have set an imap account as default BUT it continues to use my gmail email when I send a new message. It give me the drop down menu to choose the other one BUT why is that necessary if it is already the default. Thanks
Sally Tang
Are you in the IMAP account or your Gmail account?
If you are in your Gmail account, it will send emails from your Gmail account by default.
So, go to your IMAP account and try to send email again. It should send from your IMAP account.
Best Regards,
Sally Tang
F how do i set a reminder in onenote 2010 Using Outlook 8
David Michaels VB coding works in OL 2010, but not in OL 2013 Outlook VBA and Custom Forms 4
