How to Find Registry Key Command for Outlook 2010 Issue?
JacklBarrett
How do I find the registry key below?
I go to Regedit>Local Machine>then all i find is software programs listed. How do I find this specific registry key to correct Outlook 2010 link issue?
" This operation has been canceled due to restrictions on this computer. Please contact your system administrator.
HKEY_Local_Machine\Software\Classes\htmlfile\shell\open\command
Thanks for any help in advance......Jack
Jack Barrett
I
Ivanmor
Hi Jack,
This has helped me in the past.
If you received this error after uninstalling any application that takes over the HTML open command (including, but not limited to, Chrome & Firefox browsers) you may also need to change the HTM/HTML association in the registry.
Start, click Run, type Regedit in the Open box, and then click OK. Browse to HKEY_CURRENT_USER\Software\Classes\.html Right click the value for the .html key and select Modify... Change the value from " ChromeHTML" to " htmlfile" (or from FireFoxHTML to htmlfile)
I assume the issue you are having is when you click on a link from within outlook. You could also try resetting Web settings in Internet Explorer. If this does not resolve the issue, set IE as the default browser. If you use a different browser as your default, you need to set IE as the default until you verify the links work in Outlook.
ivanmor
M How can we find the list of users who are members of a deleted distribution list? Exchange Server Administration 2
B Search: Cannot find which Folder Contains a Message Using Outlook 3
E How to find or recover Lost e-mails within a folder under Inbox? Using Outlook 2
H "Advanced find: column for full folder path? Using Outlook 1
C Find all deleted recurrence appointments Outlook VBA and Custom Forms 4
mrje1 Is there a Find and Replace feature in Outlook 2016? Using Outlook 4
G Can't find contacts entered Using Outlook 0
Connie Boyer Exporting Outlook calendar/find next repeating meeting Using Outlook 3
B Find related messages to sender Outlook VBA and Custom Forms 7
B Find Related Emails to sender Using Outlook 1
RBLampert Outlook "can't find" my e-mail server to receive messages Using Outlook 22
M Can't find messages Using Outlook 4
Diane Poremsky Find the Distribution Lists a Contact Belongs to New Slipstick.com Articles 0
T Macro to find contacts by category and copy them to another folder Outlook VBA and Custom Forms 15
thomas zaleski Cannot find the Sending FOlder Using Outlook 2
J Find and Highlight text in outlook Outlook VBA and Custom Forms 4
J Outlook Mailbox cleanup; any way to change limit to find items older 999 days? Exchange Server Administration 2
F Disable "Find related messages" Using Outlook 1
Jennifer Murphy Can't delete or even find task attachment Using Outlook 1
K Re: Use Instant search to find messages from a contact Outlook VBA and Custom Forms 6
Andrew Hawkins "Advanced Find" Using Outlook 1
M BCM 2007 Can't find SS2012Express Using Outlook 2
O Outlook 2013 contacts - Where to find "Display as"-field Using Outlook 2
C Cant find emails after moving pst Using Outlook 1
G Find Organizer of appointment Using Outlook 2
R writing "Instant Search" queries to find User-Defined fields Using Outlook 0
P Outlook Advanced Find Using Outlook 0
S Advanced Find text field limits Using Outlook 2
C O2010: Using Advanced Find to locate exact queries Using Outlook 3
D Outlook 2007 Find All Related and Messages From Sender not working Using Outlook 3
S Cannot Find Shared Database on Remote Computer BCM (Business Contact Manager) 13
V rule to Find some words in the subject, change subject then forward Using Outlook 1
L Mapi folder.FIND: error Using Outlook 0
T Find the sender who sent the mail from Generic Mailbox. Using Outlook 4
S Can't find some addresses after a contact list export. Using Outlook 1
F Can't find all stationery listed in stationery picker Using Outlook 2
