Error: 3033 when trying to OpenDatabase using DAO
am12
I amuncesfull trying to open an Access 2003 database using DAO 3.6 within
Outlook 2003 VBA. The error.description says:
You do not have the necessary permissions to use the
<.../name/mdb> object. Have your system administrator or the person who
created this object establish the appropriate permissions for you.
The err.Number is 3033
I have tried several options such as:
1-mdb with and without admin password
2-mdb with specific mdw file while setting the filepathname.mdw to
DBEngine.SystemDB
Any idea what I should look for?
Follows a stripped down version of the code with no password set for admin:
Private Sub cmdImport_Click_Test()
On Error GoTo ErrorHandler
Dim dbe As DAO.DBEngine
Dim wks As DAO.Workspace
Dim dbs As DAO.Database
Dim strAccessPath As String
strAccessPath = "C:\tmp\test.mdb"
Set dbe = DAO.DBEngine
Set wks = dbe.Workspaces(0)
Set dbs = wks.OpenDatabase("C:\tmp\test.mdb", False, False)
ErrorHandlerExit:
ErrorHandler:
MsgBox "Error No: " & Err.Number & "; Description: " & Err.Description
Resume ErrorHandlerExit
Michael Bauer
You should know whether the db is protected by a password or an *.mdw file.
If the latter, look for your permissions for the object you're trying to
access. However, the Outlook newsgroup is not the place to ask for these
Access or Jet specific questions.
Best regards
Michael Bauer
Am Sat, 16 May 2009 19:42:01 -0700 schrieb jmv:
> Hi,
> DBEngine.SystemDB
admin:
> ErrorHandlerExit:
> Exit Sub
> ErrorHandler:
> End Sub
am12
Hello Michael,
Thanks for answering. What newsgroups should my request be posted to?
I have tried opening the db in 3 different configurations:
1-With admin password unset
2-With admin password set
3-Using a specific .mwd file.
In all of the above scenarios I am able to open the mdb with Access
but not with DAO. Any ideas?
> > Best regards
> Michael Bauer
> > Hi,
> > DBEngine.SystemDB
> admin:
> > ErrorHandlerExit:
> > Exit Sub
> > ErrorHandler:
> > End Sub
Michael Bauer
This is not my area, but I think the db is protected by an mdw file. So, if
you're able to open the db with a specific mdw set via Access, can you also
access the table or whatever then? If so, your code should be wrong; if not,
you don't have the permission to access the object. If the latter, set the
appropriate permission, or ask the db admin to do that for you.
BTW, the code you have shown doesn't specifiy an mdw file.
Best regards
Michael Bauer
Am Sun, 17 May 2009 10:00:11 -0700 schrieb jmv:
> Hello Michael,
> Thanks
file.
>> > > Best regards
> > Michael Bauer
> >> Hi,
within
> >> DBEngine.SystemDB
> > admin:
>>> ErrorHandlerExit:
> >> Exit Sub
>>> ErrorHandler:
Err.Description
>>> End Sub
D We're sorry but outlook has run into an error Using Outlook 1
D Outlook 2016 Outlook Error Msg "The operation cannot be performed ..." How to Stop it Using Outlook 3
A Error: The name cannot be matched to a name in the address list Using Outlook.com accounts in Outlook 0
Diane Poremsky The Attachment Size Exceeds the Allowable Limit Error New Slipstick.com Articles 0
Diane Poremsky RMS Error: System clock has been tampered with New Slipstick.com Articles 0
Diane Poremsky Error Opening Outlook and Control Panel's Mail Applet New Slipstick.com Articles 0
K Error: Paper Size Invalid Using Outlook 0
M Error 0x 800CCC92 Using Outlook 0
Diane Poremsky Cannot start Microsoft Office Outlook Error Message New Slipstick.com Articles 0
S Autosave attachments error using Len Outlook VBA and Custom Forms 2
J Error 75 Outlook VBA and Custom Forms 4
