Outlook 2010-could not perform function; default mail client not properly installed-when trying to a
C
CBMT
Can someone please help me with this? Outlook works perfectly when accessing it by clicking on the icon, but keeps giving an error messge: default mail client not properly installed-when trying to access from IE (64-bit), when I click on the envelope in IE. I have sent the default in Outlook 2010 and under Tools in IE. Thanks!!!
Sally Tang
Try to set the default mail client manually:
For Windows XP:
In Windows Explorer, choose View | Options. On the File Types tab, you'll need to edit the Open event for " URL:MailTo Protocol." as follows:
" C:\Program Files\Microsoft Office\Office\Outlook.exe" -c IPM.Note /m " %1"
For Windows Vista/Windows 7:
1. Open regedit.exe.
2. Navigate to: HKEY_LOCAL_MACHINE\SOFTWARE\Clients\Mail\Microsoft Outlook\Protocols\mailto\shell\open\command
3. Change the value for Default as: " C:\Program Files\Microsoft Office\Office\Outlook.exe" -c IPM.Note /m " %1"
Note: I assumed that your Office program installed in C:\Program Files\Microsoft Office.
Sally Tang
T outlook 2010 'not enough memory avaliable to perform the operation' with distribution lists Using Outlook 0
D Outlook 2010 won't perform Send/Receive on IMAP folders as scheduled Using Outlook 2
V Hotmail account on Outlook 2010 Using Outlook 2
