Outlook 2010 does (partial) not save to NormalEmail.dotm?
Remco Tiel
I've got the following situation,
When you open a mail, go to Format Text and click on the button next to Paragraph. You can set some settings here, I mark the checkbox " no space between paragraphs of same style (translation). Because of this when I hit Enter in the body of the text the cursor goes to a next line instead of a next paragraph. But when I close that mail and start over, this setting is gone.
I also tried to mark the checkbox, save it as default on all documents based on NormalEmail.dotm to no avail. We've computers with Office 2003 + Outlook 2010 and computers with Office 2010 + Outlook 2010, the problem exists in both senarios. For testing I created a Quick Part (which is saved in NormalEmail.dotm) and closed Outlook. After starting up Outlook again the Quick Part was still there so this is saved to the NormalEmail.dotm.
How can I fix this?
Jahawk MSFT
This is known issue with Outlook 2007 and Outlook 2010, but there are no current plans to address it. --However, one person logged a workaround that will help.
1. Make sure Outlook is closed.
2. Start Word
3. File | Open
4. navigate to %appdata%\Microsoft\Templates\NormalEmail.dotm
5. In the Ribbon, under the section Styles - please click the arrow in the far right down corner. (A new little dialog dropdown will appear)
6. Select Normal Style and right-click and select “Modify”
7. Click on the Format button, select Paragraph and then set the checkbox " Don't add space between paragraphs of the same style" .
8. Make sure “Only in this document" is selected
9. Press OK and close all dialog and save the NormalEmail.dotm and close Word.
1. Start Outlook
2. Create a new message
3. Go to Format Text | Paragraph Chunk | Paragraph Dialog
4. The " Don't add space between paragraphs of the same style" is checked
Have a great weekend!
Jahawk MSFT
O Outlook 2010 does not open MS Word attachments Using Outlook 1
H Reocurring outlook appointment (office 2010) does not update Outlook.com Using Outlook 3
F Outlook 2010 contact e-mail Display as: does not show contact name Using Outlook 2
P Reply All does not work in Outlook 2010 Cached mode Using Outlook 4
E Does Outlook 2010 support searching multiple .pst files simultaneously? Using Outlook 0
D Outlook 2010 randomly does not receive emails Using Outlook 3
D Does anyone understand Outlook 2010??? Using Outlook 1
C Outlook 2010 - Your network adapter does not have a default gateway. Using Outlook 1
S Outlook 2010 Journal does not record activities on Office 2007 files Using Outlook 1
J Suggested times does not work with Outlook 2010 in combination with Exchange 2007 SP2? Using Outlook 2
T Outlook 2010 does not save "sent" messages Using Outlook 1
B outlook 2010 Search does not show recent messages Using Outlook 4
C Outlook 2010 does not Clean Messages from Server Using Outlook 1
M iPad does not Sync with Microsoft Outlook 2010 Contacts, Calendar, Etc. Using Outlook 2
T Outlook Today does not display in Oultook 2010 Using Outlook 3
W How does Folder Synchonization Work in Outlook 2010 Using Outlook 1
B In Contact Properties of Outlook 2010, it does not allow me to check the check box " Show this folde Using Outlook 2
B Re: In Contact Properties of Outlook 2010, it does not allow me to check the check box " Show this f Using Outlook 2
A Outlook 2010: Conversation view does not show messages that are in a folder. Using Outlook 4
C Live Messenger does not send email messages to Outlook 2010 Using Outlook 3
J __This is on outlook 2010...I can receive but does not send out.__ Using Outlook 2
J OUTLOOK 2010 Does not check E-mail when off-line Using Outlook 7
C Managed Folder does not show up in Outlook in Exchange 2010 Sp1 Rollup 1 Exchange Server Administration 3
M In Outlook 2010, upon deleting an open e-mail, the next e-mail does not open automatically in full s Using Outlook 2
O Outlook 2010 does not store password Using Outlook 1
G Where does Microsoft Outlook 2010 save my information and configurations? Using Outlook 1
P My Outlook 2010 won't delete files, or at least, sometimes it does, sometimes it doesn't.__ Using Outlook 1
M Upgrading from Excahnge 2003 to Exchange 2010 how does it effect outlook client users Exchange Server Administration 7
B Outlook 2010 does not connect to email servers. Using Outlook 2
C Where does the sent mail in outlook 2010 go to? Using Outlook 1
C windows contacts search in MS Outlook 2010 does not work Using Outlook 1
T outlook 2010 deleting email dissapears and does not appear in deleted files folder Using Outlook 4
T Outlook 2010 does NOT start. Using Outlook 2
M Outlook 2003/2007/2010 not showing attachments but OWA does Using Outlook 6
M Does a shared Outlook BCM 2007 database work with both Outlook BCM 2007 and 2010 clients? Using Outlook 2
L Magnifying glass does not move when searching messages in Outlook 2010 and another related question Using Outlook 3
J Outlook 2010 does not show some messages after upgrade from Office 2003 to 2010 Using Outlook 1
P Outlook 2010 smtp.live.com gives error that server does not support encryption. Using Outlook 2
K Outlook 2010 spellcheck and synonym does not work with word 2007 Using Outlook 1
B Search Does Not Work in Outlook 2010 Using Outlook 2
S Outlook 2010 - Room List does appear empty in room finder / select an available room from a location Exchange Server Administration 3
L Windows Search does not Open Outlook 2010 items. No error reported. Items open fine within Outlook 2010 itself. Using Outlook 6
B Does Microsoft Office Accounting Professional 2009 integrate correctly with Outlook 2010? Using Outlook 5
V Outlook 2010: Options: Mail: Signatures does not work Using Outlook 20
A Using BCM 2010 mass email - how do you control which outlook email account does the sending? Using Outlook 6
T Outlook 2010 - "The file does not exist" when changing options Using Outlook 4
